You might be in luck after all. I just took a look at the cluster that came out of my truck. I expected to see a hook up for the tach separate than the regular gauge and light plug in. Turns out the tach's integrated in with everything else. So unless Ford produced a completely different under dash harness for tach equipped trucks (unlikely) then it's just a matter of where the under hood wires should hook up to feed the under dash.
I followed the circuits, (they are labeled 1,8,G, & B.). B&G just hook up to the light circuits, 8 goes to the top, third from the left connector. 1 goes to the top, second from the left. If the non-tach trucks have wires at these connections and they are not being used for anything else then hooking up that tach just got easier:
Sorry if this is a stupid question but I thought you could do this without removing the injection lines? Is this step necessary or does it just make the job easier?
I've never tried to swap housings, just going off what I read in another thread, plus what I did when swapping IP. I'm pretty sure you'll have to take the lines off the injectors to be able to get the pump to move back far enough to clear the housing. You may be able to leave them attached to the pump though.
If your housing doesn't have a plug for the sensor, then you probably don't have the wires in the harness either.
Really easy to wire a tach in (I mounted the Ford unit into my Chevy cluster when I did my swap).
4 connections on the gauge, 12v+, two Grounds and one from the Sensor.
The sensor has 2 leads, one will go to the gauge (Sensor), the other can go to a good ground or directly to one of the Grounds on the gauge.
Simple, just took me a while to go through a harness and about 4 connections to find it out.... This goes for all of the stock IDI tachs.
More good info on this topic from another guy that needs reps I cannot give:
Originally Posted by Ford F834
Well, it was not exactly cheap but putting a tach in a 85-86 truck that has the wiring and IP gear housing port was ~super easy. Sensor, printed circuit film, tach unit, done!
(Video)
Originally Posted by Chevy_Eater
So the wiring was in place, correct? It didn't make sense that there'd be a different wiring harness, but you never know what a manufacture is thinking.
Correct. The wiring was already there. But 1983 and 1984 diesels did not have a tach option, and their wiring harness was different. They also lack the threaded plug for the sensor in the IP gear housing. On 80-86 gas trucks the tach wiring is there except if you have a truck with warning lights instead of gauges.
