fine tune 351
Old Apr 1, 2013 | 10:53 AM
redroad's Avatar
redroad
One of the large ports should be connected to brake booster and the pcv should look like the pics
Old Apr 1, 2013 | 10:58 AM
Wbruiser2's Avatar
Wbruiser2
Did you try just unhooking the pcv from the back of the carb and capping that port to see if that fixed the problem? The reason I suggested you try that is because sometimes the pcv is a vacumn leak that causes the stumble/ hesitation. Hooking it up to the manifold will give you the same result if it is the culprit.
Old Apr 1, 2013 | 11:48 AM
redroad's Avatar
redroad
most of these motors run what is called positive crank case pressure .. This is probably fine if your motor is stock and running off 87 octane fuel but lets say you've bumped the compression ratio exceeding 8:7 to 9:0 and you need a higher octane fuel .. Putting atomized oil particulates back into the cylinder is going to defeat the higher octane fuel requirement, which is what the pcv system is doing .. so this is the solution by plumbing it in line the heavy's fall of into the canister and you just drain them off periodically .. It makes no sense to diminish the fuel your paying for even if it's 87 octane
Old Apr 1, 2013 | 04:44 PM
pinehillian's Avatar
pinehillian
unhooked pcv - capped carb. fitting and still same-changed timing varius degs same. i think carb related, tried varius lean rich adjustment-accel pump i think is close got nice squirt at sqiurters- someone mentioned throttle plate, how can i check that
‘66 F100 Pearl
Nov 28, 2018 01:07 PM
olblue77
Feb 25, 2018 01:59 PM
countryF150
Apr 21, 2007 01:24 PM
staysbroken
Jan 4, 2006 10:56 PM
WrenchHead84
Oct 15, 2002 09:16 PM
