Sponsored by: Kumho
Rear Drums Sticking?
Old Mar 30, 2013 | 11:51 AM
blue76's Avatar
blue76
I have A 97 F-150 4X4 with rear drums. I noticed the brakes felt like they werent releasing right away after i let of the brake pedal. i took drums off and noticed on the left rear the front shoe moved normal but the rear shoe didnt move at all. on the right side front shoe moves normal rear shoe very very slow, and i could see rear shoe was worn way more than front. So i relplaced on both rear the shoes, all the hardware, springs, wheel cylinders and brake line from cylinders to the proportioning valve.bleed the brakes, and adjusted the drag on the drums. Now i drive it, test it out, feels like the same issue is going on. feels like im driving with the brake on, and right rear gets really hot. Did i miss something? not do something right? anyone have any ideas?
Old Apr 4, 2013 | 10:50 AM
ClickClickBoom's Avatar
ClickClickBoom
Did you wirewheel your backing plates to get rid of any rust/ built up dust (wear a mask!). Also should make sure that your adjusters are lubricated, and your pistons on the wheel cylinders aren't rusted.
Old Apr 4, 2013 | 12:50 PM
Beechkid's Avatar
Beechkid
Check the rubber brake lines- they could be falling apart/collapsing on the inside
Old Apr 6, 2013 | 01:07 PM
blue76's Avatar
blue76
Found it! The right rear parking brake cable was sticking. I disconnected the cable from where it splits off from the parking brake cable, could move the left side but not the right. So i guess its time to get a new right side cable. I guess the cables will rust inside the sheath.
Old Apr 6, 2013 | 08:58 PM
Beechkid's Avatar
Beechkid
Good catch!
RBhokiefan
16
Mar 18, 2017 07:21 PM
tuxedobuttonquail
Sep 23, 2016 03:40 PM
wiley15
Aug 6, 2011 01:11 PM
blazerf250
1997 - 2003 F150
Dec 29, 2004 08:30 PM
Muddr Trukkr
May 21, 2004 07:56 PM
