fuel guage
Old Mar 30, 2013 | 10:54 AM
jamhh's Avatar
jamhh
fuel guage
I'm tring to test my fuel guage. I have power at the tank, but my test light flashes just like it does when testing a signal light? Is this normal?
Old Mar 30, 2013 | 07:34 PM
spurredon's Avatar
spurredon
Huh???????
Old Mar 30, 2013 | 09:57 PM
FJones8668's Avatar
FJones8668
Hahaha x2^^ Power? at where now?
We need a little more information to help you please :P
Old Mar 31, 2013 | 07:53 AM
economan's Avatar
economan
This is a good thing...
it tells you the constant voltage regulator (that thing with a female & male spade connector)on the back of the cluster is working properly, it basically just shoots those little bits of power to the gauge(s) to keep em from burning up.
this means you have + power to the gauge, the gauge takes the reading on the negitive side and the sending unit in the tank (basically a rheostat) goes back to the
ground via the body. three things basically can only go wrong as a rule:
1-make sure u have a good clean connection from/on tank to sending unit screw on to the body of the truc, thus grounding the tank
2-pull the sending unit out & make sure u don't have a sunkin float by unclipping it & give it a shake to make sure it ain't fulla gas.
3-look @ the windings on the "rheostat" make sure they're not broken, & the contact point is touching em & looks healthy.
this is of coarse assuming you have already checked the (orange) wire from the tank to the gauge for continuity.
this can be e-z done by with key in on position touching it to ground(just for a second) the gauge should shoot up to "F" real fast. or run a dummy jumper wire from the non flashing side of the gauge to the dash in the same fashion to check the gauge itself
hope this is simple nuff explination & u get it sorted real soon
mikie
near ottawa canada
58 merc panel &64 econoline p/u
Old Apr 1, 2013 | 09:15 AM
jamhh's Avatar
jamhh
Thank you very much. Turns out it was a sticky float
Jordan
Bluey Zedoff
Electrical Systems/Wiring
Jul 18, 2015 07:43 AM
ebbtide
27
May 24, 2012 05:11 PM
BossFan
Nov 21, 2011 10:32 PM
BossFan
Nov 13, 2011 04:27 PM
tealboy1
Dec 28, 2008 04:28 PM
