79-wiring
Old Mar 29, 2013 | 04:07 PM
pinehillian's Avatar
pinehillian
79-wiring
under hood coming out of firewall , besides the ones going to the electronic ign,-tan colored square plug 4 wires, the plug that connects to it has 3 wires coming into engine compartment. with key on, and testlight 1 is real bright-1 is real dim 3rd one flashs -noblink or flashers on-, trying to find why alt light is always on
Old Mar 29, 2013 | 05:04 PM
redroad's Avatar
redroad
Take a picture and post it
Old Mar 29, 2013 | 05:44 PM
pinehillian
grayish connector- 3 wires coming out bright lit 1 goes to coil other 2 have rubber boots like old sending unit wires-1 flashs 1 real dim [checking with test light] alt light still on on dash
Old Mar 29, 2013 | 05:58 PM
redroad's Avatar
redroad
79 F250
Old Apr 1, 2013 | 06:30 PM
fmc400's Avatar
fmc400
MSEE
We still have no idea what you're talking about. Please post a picture, specify the color of each wire in question, and describe more clearly what you are doing.
Old Apr 1, 2013 | 06:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I think he's trying to figure out why his ALT light is always on.
To the OP, your second question. That sounds like the engine gauge feed harness. The three wires should be Red/green trace goes to coil, white/red trace goes to oil pressure sender, red/white trace goes to temp sender. This shouldn't have anything to do with your problem.
Also, you can go here for copies of the factory wiring diagrams http://fordification.net/tech/wiring.htm
Old Apr 2, 2013 | 06:58 AM
pinehillian
CORRECT!
Also, you can go here for copies of the factory wiring diagrams 1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
i installed mechanical gauges, oil pr. -temp,removed old sending units but wires are still in truck, checked with test lite -just to try to do away with unneeded wires and figure why alt lite is on. alt and reg. check out good-one of the wires from old temp-oil pr. flashs and other seems dim,3rd one goes to coil and in use
Old Apr 2, 2013 | 06:30 PM
fmc400's Avatar
fmc400
MSEE
The sending unit wire that's flashing is likely the one that went to the temperature gauge; it's flashing because you're seeing the output of the ICVR, which is a switching regulator.
As far as the ALT light being on, remove the connector running to the regulator. The terminal that goes to the 'A' terminal of the regulator should have 12 volts at all times. The terminal that goes to the 'I' terminal of the regulator should have 12 volts with the key in RUN. Report your results.
Old Apr 3, 2013 | 04:40 PM
pinehillian
have some voltage numbers may help you help me, battery w/key off 12.42 key on12.21 - I term. 11.40 key on 0 key off -A term. 12.42 key off and 12.15 key on ps think maybe i should put old sending units back in and hook up the other wires
Old Apr 3, 2013 | 04:56 PM
redroad's Avatar
redroad
No offense but we need better communication
.. It will give new meaning to your readings
battery with key off = 12.42
with this example put the rest in that form
Old Apr 3, 2013 | 05:21 PM
pinehillian
A termina with key off = 12.42v A terminal with key on = 12.15v I terminal with key off = 0v I terminal with key on = 11.40v battery with key off= 12.42v battery with key on = 12.21v
Old Apr 3, 2013 | 06:16 PM
redroad's Avatar
redroad
"A" terminal with key off = 12.42v
"A" terminal with key on = 12.15v
"I" terminal with key off = 0v
"I" terminal with key on = 11.40v
Old Apr 3, 2013 | 06:33 PM
pinehillian
when i put all that info in it looked identical to the way you have it,when i hit submit reply it went into sentences, maybe i should get better on the computer before i ask any more questions
Old Apr 3, 2013 | 07:51 PM
fmc400's Avatar
fmc400
MSEE
I read you loud and clear; thanks for the information. This tells us that power is getting applied to the voltage regulator properly.
The next thing is to make sure that you have continuity between the alternator output and the battery, in order to make sure the fusible link is not blown. The safest way to do this is to disconnect the negative battery cable, then measure the resistance (ohms) between the alternator output stud and the battery side of the starter solenoid. The resistance should be no more than the resistance of your meter leads.
Old Apr 3, 2013 | 08:34 PM
pinehillian
i alread checked that while switching alt. and reg. dont remember the # but big black wire from alt to soliniod with fuseable link tested good. i have couple ignition switchs, maybe i`ll try changing one?
