Engine Hoist? Plan 'A' failed, what's Plan 'B'?
Old Mar 29, 2013 | 04:42 PM
overlandexpress's Avatar
overlandexpress
Post on Cragslist that you would like to rent someones engine hoist for a day or half day, offer a beer if they want to spend 5 minutes helping you! I'm sure some motorhead has one sitting in there garage around there. I bought a truck and posted an ad for someone to trailer it up 600 miles to me and found a guy that was headed this way with an empty trailer, I gave him $200.00 and he delivered my truck to me! Craigslist works!
Old Mar 29, 2013 | 04:47 PM
redroad's Avatar
redroad
Originally Posted by lafermedavid
you know how it is you do what you have to do when your one person,dealing with the trusses you might want to span a header and legs under the truses for support and lift away with surety
Yep I know exactly how it is .. We live at the end of the road here .. I wouldn't know where to go to rent something that wouldn't cost me at least $40 in fuel
Old Mar 29, 2013 | 04:50 PM
redroad's Avatar
redroad
+1 on the asking a motorhead
Old Mar 29, 2013 | 05:40 PM
jim collins's Avatar
jim collins
Originally Posted by taneum
My ceiling is composed of 2x4 floor trusses 21" tall, 19" o.c. The ceiling is sheeted with 7/16" osb which would have to come off, not a huge deal. I thought the block would weigh more that 275lbs. with heads, intake, and crank shaft removed??
It sounds like what you have is a truss make sorta like a I-beam . 2x4 flat on the top and bottom with a plywood webbing foaming an [ I ] .If so . do not cut any of it as it is engineered to span the distant it goes from wall to wall. They are engineered to have weight push down on them and never pull down from the bottom . Pulling down will pull the lower 2x4 apart from the webbing , then very bad things happen. You could put a 4x4 like redroad said if you put it on top, but then you will need a hole though the upper floor if it is finished. Buy a cherry picker then sell it is my suggestion.
Old Mar 29, 2013 | 05:47 PM
redroad's Avatar
redroad
I still have my older walker american made hoist but my buddy bought one of these and they are pretty good and free shipping .. I think he payed $225 http://www.ebay.com/itm/4000-LBS-Engine-Cherry-Picker-Hoist-Shop-Crane-2-Ton-/290887561145?pt=Motors_Automotive_Tools&hash=item43ba3fefb9&vxp=mtr
Old Mar 29, 2013 | 05:55 PM
jim collins
Originally Posted by redroad
I still have my older walker american made hoist but my buddy bought one of these and they are pretty good and free shipping .. I think he payed $225 4000 lbs Engine Cherry Picker Hoist Shop Crane 2 Ton | eBay
That's a good looking one and it looks like it folds up for easy storage . Mine don't and that was a mistake i made , but i do take it apart for storage sometimes if i have no plans to use it for a few weeks.
Old Mar 29, 2013 | 06:13 PM
lafermedavid's Avatar
lafermedavid
engine hoist
thats a great suggestion overland express suggested,motorheads help others
Old Mar 29, 2013 | 06:14 PM
brian1080's Avatar
brian1080
I bought my fold up cherry picker at harbor freight a while back for like $150. I've pulled about 5 engines including my 460 with it and love it.
Like was said before, if you strip the engine )heads/intake/exhaust/etc( then you can probably pull the block by yourself. I've lifted one of these blocks with crank/pistons by myself, and if you are just turning it around to put on a stand you will have help from the frame.
Old Mar 29, 2013 | 06:53 PM
JWC 3's Avatar
JWC 3
I planted 2 6x6 ceder posts in the ground and topped them with another one . A chain hoist and a cable hoist worked great for years .Then I built a 5 bay shed and put up 6x6 beams in 2 bays to pull from . I still use them sometimes . But now I have a 2 bay shop at home with a concrete floor and a nice engine hoist . Improvise , a few well planted posts can work for cheep .
Old Mar 29, 2013 | 07:26 PM
Vinford's Avatar
Vinford
3 long poles or 4x4's in a tripod.
Chain it together on the ground and as you push it up it binds and tightens up.
Put a chainblock on it and your good to go.
Ive seen hundreds of 3 pole setups, its all anyone used to use around here for pulling a motor.
Old Mar 29, 2013 | 08:31 PM
73 ford guy's Avatar
73 ford guy
To move body parts I use my front and rear winches. Box install was a breeze. Ran rear winch up and to the front to a crossmember back to rear and hooked to box. Cab I got creative. Winch to car back to side of frame with temporary tube welded on frame with shackle then out the side of truck like pic below
I dragged old cab away like this.
once cab was dragged up it needed to level out with a jack and
Some wood planks, then kept winching up.
Old Mar 29, 2013 | 08:42 PM
73 ford guy
O yeah and these...
Hanging doors.
Cage removal..
And front clip
Old Mar 29, 2013 | 09:37 PM
  #28
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Do not mess around with your home, great way to jack up you insurance with some cobbled up support that fails and then what you going to do?
Like its been said, just get on the c list wanted add and rent one for a day or too or buy one you will need it for the install anyway.
Since it sounds like you are a 1 man show, get a cherry picker and do it safely. Find a guy with a old school split boom wrecker truck or a "gin pole" set up. Get a guy with a tractor and a front end loader.
Rent a bobcat/skid loader, lots of construction business have them, explain your situation and they might even provide a operator for the short time needed.
Even a tractor with a rear 3 point pole will pick that motor out. Build one of these in the pic, I have pulled motors, front clips, beds, even unloaded that Bronco shell off the trailer with it.
Old Mar 29, 2013 | 09:53 PM
  #29
77&79F250's Avatar
77&79F250
Have you even signed up with your FTE state chapter and ask around in there? I have had a few wrench fests with the folks I have meet thru my state chapter.
South Dakota Chapter - Ford Truck Enthusiasts Forums
Old Mar 29, 2013 | 11:15 PM
  #30
tbear853's Avatar
tbear853
I've got a few coupon adds saved, I've been thinking of the 1 ton version (lot nos 69445 / 69512 / 93840) that is normally $199.99 (but recently was raised to 229.99 it seems) for .... $99.99
The latest add shows the higher regular price raised. That $99.99 is good to July 24 (limit 5). Maybe I should latch onto one? Best price on net is 179.99? Last time I was there a couple weeks ago, was going to get one but they didn't have a fork trk driver on duty to get it off top of stack in store room.
Shop Crane, 1 Ton Capacity Foldable
