Had alignment done.
Old Mar 29, 2013 | 02:13 AM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
Had alignment done.
Took the Ex to the alignment shop today after replacing the castor nut a few weeks ago along with new ball joints on the drivers side. I have no idea what the numbers mean so if anyone can let me know Id appreciate it. Thanks.
File Type: pdf
Old Mar 29, 2013 | 05:18 AM
Rainmaker68's Avatar
Rainmaker68
The drivers side is definielty looking better passenger side but for the most you are equal on both sides the passenger has more positive caster than the other, that wheel will pull toward the center of the vehicle as well as unequal side-to-side camber of 1° or more will cause the vehicle to pull or lead to the side with the most positive camber. The caster caster is telling me that the lower ball joint is +6 degrees in front of the invisible vertical line, which could be some play there. Nothing should up in the turn so as long as the steering isnt throwing you around and it runs straight keep it going.
I think 6 degrees is the max for castor.
Old Mar 29, 2013 | 05:23 AM
Rainmaker68
Old Mar 29, 2013 | 05:38 AM
Misky6.0's Avatar
Misky6.0
I would recommend tire kingdom.
Make sure the particular shoo has the rack big enough for the excursiion. They provide a computer readout with before and after measures along with the specs. Makes it easy to read and you can tell what -if anything - they adjusted. Results are color coded green or red for within or out of spec. I have used them for over 20 years.
Old Mar 29, 2013 | 08:53 AM
ROBBINthaHOOD
I had actually lost my castor nut (possibly had came loose from the accident back in June) a couple of months ago or less and I had no idea what to get so I got a 2 degree and just turned the slot to match where the passenger side slot was. Just did the ball joints a couple of weeks ago on the drivers side. Was still tracking straight even with the 2 degree castor. We are fixing to put about 300 miles on her today so Ill be able to see if I can tell a difference. Misky, my readings are in the pdf in my post. Thanks.
Old Mar 29, 2013 | 03:46 PM
Rainmaker68
It definitely needed it the final adjustment again looks good you should be good. I just always replace my ball joints in pairs.
Old Mar 29, 2013 | 05:56 PM
ROBBINthaHOOD
Yeah both upper and lower were replaced.
Razkid
Sep 10, 2017 07:33 AM
green_95
Jun 8, 2016 07:29 PM
flkeysff
13
Sep 20, 2013 04:52 PM
keisha9
2004 - 2008 F150
Mar 5, 2011 10:06 PM
bronco351
1978 - 1996 Big Bronco
Oct 10, 2003 09:18 PM
