Sponsored by: Auxito
4.6 VS 5.4?
Old Mar 29, 2013 | 01:42 AM
Nevergetstuck's Avatar
Nevergetstuck
4.6 VS 5.4?
Is there a major difference between these two? I've ridden in a stock truck with a 4.6 and a lifted truck with a 5.4,so with my experiences I cannot compare.
However,when looking for a truck I've been skipping trucks with a 4.6 due to the fact that I want to lift the truck,say 6-8" of lift with 36-37" tires? The gears would be stock for awhile,but would be replaced with 4.56 or 4.88 when I got the cash.
Old Mar 29, 2013 | 08:56 AM
BigBlockF350's Avatar
BigBlockF350
With the lift you want to do, go for the 5.4. It should have a easiest time with those bigger tires.
Old Mar 29, 2013 | 11:49 AM
Sxynerd's Avatar
Sxynerd
Same Hp, more Tq. The blocks just a bit wider with a longer stroke. Same heads.
The 4.6 is easier to get mods for (Intakes, S/C, etc) but in a truck that weighs a lot, I'd go for the 5.4.
The 4.6 in a lightweight 2wd race truck could work fine although there's always the Lightening swaps with the 5.4. (Which I think is over rated if you want to mod right the first time and want big numbers.)
Old Mar 29, 2013 | 06:49 PM
Nevergetstuck
I'm assuming this is similar to the 302 Vs 351W,the 302 will do perfectly fine but the 351W will do just a little better.
Same concept right? There is nothing wrong with either the 302 or the 4.6,but the 351 and 5.4 are just a step ahead?
Old Mar 29, 2013 | 07:11 PM
sshanee's Avatar
sshanee
5.4 makes 350 torque at like 2000 rpm, much stronger engine. also dont forget if you want to change the rear diff ratio you also need to change the transfer case gears to match if it's 4x4.
Old Mar 29, 2013 | 07:20 PM
shapleigh's Avatar
shapleigh
sounds about right, but application is key i think in decision like this one, I say go 4.6 if you want a higher revving daily driver / race truck, go with the 5.4 if you want a workhorse / rock crawler, just my opinion from what i've heard, I'm sure some one will correct me if I'm wrong :P
Old Mar 29, 2013 | 07:24 PM
Nevergetstuck
The truck will be my daily driver but I want to be able to take it off road too. I'm not going to go sink it to the hood in mud,but I want to be able to take it out and play with it. Eventually I'm gonna get an older F-350 for the serious muddin'.
Old Mar 29, 2013 | 08:30 PM
shapleigh's Avatar
shapleigh
in that case i would def go the 5.4, otherwise you'll overwork
the 4.6 in the mud, unless you have oem tires "imo", but i'm basing my opinion on limited test....
Old Mar 29, 2013 | 10:13 PM
MIKE 04 GT's Avatar
MIKE 04 GT
You do not do anything to the transfer case when doing gears, If you are 4X4, you just change the gears in the front diff to match the ones in the rear
ie( 4.56 in the front diff aswell as 4.56 in the rear diff). nothing in the T case.
I have owned both,
My 97 had the 4.6, it was a regular cab, after i put on 285-75-16 MT i could tell a huge differance, and it got worse gas mileage than my 5.4. also pulling trailors, it was allway shifting down on the smallest grade.
My 02 has the 5.4, It is a supercrew, I ran it for 2 years with 315-70-17 with no problems, I even towed my 25' Camper with no problems. you can def tell the differance between the 2. i now have 4.56 gears in this one w/ 35's.
If you have the choice go with the 5.4
like said above, same hp, but Tourq is better with the 5.4
99-03 4.6 has 260Hp, 300 TQ
99-03 5.4 has 260Hp, 350 Tq
But the 4.6's 300 Lbss of tq is like 4200 RPM where th 5.4 is @ 2200 rpm. .
With a lift planed, i would def go with the 5.4.
Sean02SD
2004 - 2008 F150
68
Apr 3, 2006 04:36 PM
bagels1622
Modular V8 (4.6L, 5.4L)
32
May 30, 2005 11:05 AM
1248bullitt
1997 - 2003 F150
Aug 18, 2002 12:39 PM
fordmandan
1997 - 2003 F150
Oct 4, 2001 11:08 AM
