Horrable idle
Old Mar 28, 2013 | 06:51 PM
bchnut's Avatar
bchnut
Horrable idle
Ok I've been throwing a code for #3 cylinder compression balance. Idles rough and hesitates on initial acecleration than comes alive when you put aload on it. Smokes from white to black then clears. First rebuilt my FICM... no help, did continuity test on wiring harness...it's ok. Replaced injector...no help. Today I opened the valve cover and noticed a push rod was bent so I replaced both the rods on that cylinder... still no help. I'm thinking the worse at this point. Any suggestions? By the way It sounds like the intake is a muffler!
Old Mar 29, 2013 | 10:31 AM
BLADE35's Avatar
BLADE35
so did the old inject have a tip on it when you puled it out
sounds like somethings was in there or it hydrolocked to cause push tubes to bend
At minimum it needs a compression test on that cylinder
the Piston my have a Hole
Old Mar 29, 2013 | 11:17 AM
ryhed's Avatar
ryhed
Ouch, it reminds me of a 93 page rebuild I just glanced at!
And the other 15 page one!
Old Mar 29, 2013 | 11:55 AM
dannyboy950's Avatar
dannyboy950
With the intake sounding like a muffler I would suspect a valve issue you may have chipped a valve by ingesting something which can also account for the bent push rods.
Old Mar 30, 2013 | 08:22 AM
bchnut's Avatar
bchnut
Did a compression test and it is low on that cylinder. So whats next? Pull the head off?
Old Mar 30, 2013 | 08:51 AM
bchnut's Avatar
bchnut
On another note, when I replaced the push rods the ones that came out are longer than the ones that a ford dealer gave me. It seems that shorter rods would not allow the valves to open fully
FordOwnerJoey
Aug 30, 2012 10:28 AM
xrufx
22
Apr 5, 2011 01:02 AM
Sillbeer
16
Sep 24, 2008 03:13 PM
yeomansjon
1983 - 2012 Ranger & B-Series
Aug 5, 2008 10:43 AM
Brian68
15
Feb 28, 2003 11:35 PM
