Help!! Electrical woes!!
Old Mar 28, 2013 | 04:51 PM
truck7575's Avatar
truck7575
So I get in my X today and she fires right up as usual... Then the battery light started blinking then stayed on... Then I hear a click and all my stock gauges go out my window and lock switches don't work and my radio doesn't work... Battery light stays on and all signals work as do the mirrors and everything else... I turn the truck off then back on it all comes back on.. 15-20 seconds later I hear the click and all the same stuff is off again.... No seemingly applicable fuses are blown... And the behavior is repeatable... Ideas?
Old Mar 30, 2013 | 04:19 PM
Hessdawg's Avatar
Hessdawg
It almost sounds like a relay or maybe ignition switch
Old Mar 30, 2013 | 04:44 PM
truck7575's Avatar
truck7575
Hooked up my AE and I was getting over 16 volts so I changed out the alternator since the voltage regulator is inside and now I'm getting a steady 14.2 volts and everything works fine now... Thanks for your help
Old Mar 30, 2013 | 04:46 PM
Hessdawg's Avatar
Hessdawg
Well maybe the computer it smarter that we thought
Old Mar 30, 2013 | 04:51 PM
truck7575's Avatar
truck7575
There is a circuit breaker in the fuse box that I would surmise is for that exact situation...
brian1985f150
19
Feb 7, 2017 05:52 PM
chazskinz
38
Oct 30, 2015 07:17 PM
truck7575
Apr 4, 2013 09:11 AM
rudedawg
Dec 7, 2009 06:14 PM
dixiemudder04
Electrical Systems/Wiring
Aug 24, 2008 07:44 AM
