Engine pinging after tune-up
Old Jun 4, 2013 | 01:36 PM
DoofusOfTheDay's Avatar
DoofusOfTheDay
update on pinging
Well, mechanic bumped up timing to almost 14, and much less pinging. Was also having an issue in general driving at say a constant 45 MPH the truck would start bucking. Giving it some gas would stop the bucking. FWIW, the bucking at 45 MPH is not the torque converter sticky issue that affects F150s. I did have that issue on my last F150 and different. So, that shuddering at 45 MPH seems to have been fixed also.
Old Jun 6, 2013 | 11:51 AM
DoofusOfTheDay
ugh, still some surging/bucking
Ugh, still some surging/bucking when driving at a constant speed. Giving it a little gas resolves issue. What the heck is wrong? I've given the mechanic some time to resolve this, but not sure he knows what is wrong.
Old Jun 6, 2013 | 12:50 PM
skyfox10's Avatar
skyfox10
Check to make sure that you don't have plug wires touching each other or running to close together. The high voltage can induce current in another wire running to close to it.
Did you ask your mechanic if he did indeed pull the spout when he adjusted the timing?
What kind of plugs were used?
what brand of wires?
Old Jun 6, 2013 | 01:20 PM
jas88's Avatar
jas88
Increasing the timing and getting less pinging doesn't make any sense.
Old Jun 6, 2013 | 01:34 PM
White 97 xlt's Avatar
White 97 xlt
Yep!!! It would "NORMALLY" be, increase timing = increase pinging.
I would suggest a MORE knowledgeable mechanic!!
Old Jun 6, 2013 | 01:36 PM
skyfox10's Avatar
skyfox10
First time I ever adjusted my timing, I turned the dist the wrong way and severely retarded the timing. I corrected this mistake seconds later, but I will say the motor sounded very creepy being that far retarded.
Old Jun 6, 2013 | 02:41 PM
Encho's Avatar
Encho
The Southernmost Mod
What's the current gapping of those spark-plugs? the stock should be 0.042 - 0.045, advancing the timing should benefit from a 0.055 gapping.
Old Jun 6, 2013 | 02:59 PM
timbersteel's Avatar
timbersteel
Is this a ASE certified mechanic or certified shadetree mechanic? Advancing a correctly tuned ignition will yield good results OR to far advanced will result in pinging. What plugs were used? Platinum or copper? Does this mechanic work on Chevy or Ford more? I dont think he's got a clue for this year truck. Either there's to much carbon in the cylinder or need to find a different mechanic.
Old Sep 9, 2013 | 07:46 AM
DoofusOfTheDay
Update on truck pinging/not running right
Well, I happened to be giving a mechanic(a really good, certified one!) a ride in my truck and within 30 seconds he said "you're truck is misfiring a little". I told him about tuneup and timing issues etc. He said to take it to a certified Ford Mechanic, so I went to dealer and I know, I paid up the A$$ for the diagnostic costs and the labor, but my truck now runs great!!! The TPS, ignition module and stator(distributor installation) were all issues. No pinging, no bucking or hesitation, just runs great.
Old Sep 10, 2013 | 11:40 AM
skyfox10's Avatar
skyfox10
Glad to see a follow up on this one. I had been waiting to see what the culprit ended up being.
Rod Beauvex
Feb 24, 2014 07:40 PM
jssblues
1978 - 1996 Big Bronco
Mar 6, 2012 01:08 AM
88 250
Oct 7, 2010 08:39 PM
heep70
Nov 6, 2003 03:50 PM
Old5
Feb 26, 2003 01:55 PM
