Blueovalfe, I still think you would be happier with a 78-79 set up. you would end up with the switches in the wheel, a lit up shift selector, and tilt steering if that's the column you find. I got the below info from fordification.com
The major change between the two era's of columns is the hazard light switch, which is on the column of the '78-79 column and on the dash or in the glovebox on the earlier trucks. The '78-'79 non-tilt column's wiring and harness is the same as the tilt version, except for the horn circuit. When you plug the column harness into the main harness, what was the horn circuit would now control the cruise control. The main control box for the cruise control is located inside the cab on the firewall. The horn would then (still going through the cruise control circuits) be operated through a relay which is attached to a dash brace behind the instrument panel.
In addition to the cruise control's control box, there is one for the brakes.
To add cruise control to your truck, and utilize the cruise features built into the column, there are several parts required:
the switch on the brake pedal which disconnects the cruise control (non-cruise trucks have the brake light switch mounted onto the side of the brake pedal, but will be substituted for the style that mounts on the vacuum booster pushrod. The cruise shutoff switch will then mount in it's place on the brake pedal)
4 way flasher switch: 1961/66: Dash if present, as it was an option / 1967/69: Inside glovebox / 1970/72: On dash / 1973/79: Made as part of the T/S switch-button protrudes from left side of column.
1973 was the first year that the shift indicator dial lit up. 1975/77's with S/C: The switch is located in the horn pad. It's located in the horn pad of 1978/79's, but the wheel and pad are different than 1975/77's.
1973/77 F100/350 columns have different steering wheels, T/S switches, horn pads, shift collars than 1978/79's. 1973/77: NSS located on column. 1978/79: NSS located on transmission.
You are correct as usual Numberdummy. I am new to this Forum and already caught the awesome job you do. I've been selling Ford parts since 1978 so I know all the work and research you put in to your answers.
There are those differences between the columns per the different generations. but swapping out the whole column and steering wheel as an assembly bolts in. As far as I've read needing only to play with the wiring a tad and the later model 3a525 steering coupler (rag joint). I have a 1979 tilt/cruise column I plan on putting in my 1968 f250 someday. Right now I have too much invested in the original column, Including 13341,3517,7b033,13a821, and a nos c7tz7a216a.
Just curious. An old Air Force buddy I was stationery overseas lives there now, originally from Roxboro. He's an old gearhead that's going to meet us in Memphis on the Hot Rod Power Tour.
What's his name? I am also originally from Roxboro.
I used Dakota Digital cruise control in my 63 F100 and it works great. I have a vss in mine but there adaptor should work fine. No complaints at all from mine.
