75' 460 starting problems
Old Mar 29, 2013 | 04:53 PM
redroad's Avatar
redroad
Originally Posted by Feardeere7
There is a metal box on the driverside inner fender that is about a 4" by 4" square and has 3 or 4 fins on the right side of the box. Would this be the duraspark box? I have not touched the distributor.
Yep that's It duraspark .. Does the wiring lead to the distributor?
Old Mar 29, 2013 | 08:41 PM
Feardeere7's Avatar
Feardeere7
No it does not, it goes back to the wiring harness below and under the break booster.
Old Mar 29, 2013 | 09:29 PM
redroad's Avatar
redroad
That's good as long as it's connected it makes it's way to the right spot some times you can have a bad duraspark box on the fender well and they may have switched to the distributor they had (points) .. Just verifying you have a hooked up duraspark ..
Old Mar 30, 2013 | 08:39 AM
Feardeere7's Avatar
Feardeere7
Yup it's connected, is it possible to check the duraspark box?
Old Mar 30, 2013 | 09:16 AM
redroad's Avatar
redroad
The box can leave you stranded .. That being said buy a new one put it in and test if that was the problem buy another and take it with you where ever you go and toss the old one .. If it wasn't it take the old one with you where ever you go ..
Old Mar 30, 2013 | 10:00 AM
Redtires019's Avatar
Redtires019
Originally Posted by devino246
Oh no, no. Bad points certainly can, but I was referring to NumberDummy's the Duraspark ignition module's tendency to temporary crap out when it gets hot and is on its way out. In either case, the OP is having cranking problems, which have nothing to do with the ignition system.
More than likely, the starter is bad. Cables could also be bad. Perform a starter circuit voltage drop test to rule out connection and cable problems.
Starter Circuit Voltage Drop - YouTube
I agree with this post, it is most likely the starter. I would check the battery and starter solenoid first however it sounds like the brushes are worn in the starter and are not making a good contact.
Old Mar 30, 2013 | 11:38 AM
Feardeere7's Avatar
Feardeere7
Okay guys, thanks for all the input. I'm gonna work on her tonight and ill let you know what I come up with.
Shanef1501176
2009 - 2014 F150
Oct 16, 2017 09:54 PM
bronkntrukholik
Aug 4, 2013 12:40 PM
IT_Dude
Nov 6, 2011 04:40 AM
TRITON-ic
2004 - 2008 F150
Nov 30, 2004 02:05 AM
