Something in the drivetrain, sounds like running over the rumple grooves that they cut to wake folks up when they go over the line.
It only happens after a little bump in the road. I have heard it a few times in the last few weeks, just a 1 or 2 second bleep, but today it stayed on for 30 seconds or so. I could not duplicate that duration but the short bursts happen on bumps on or off the foot feed.
I have been under it searching, there is some slop in the carrier but u joints feel sound. Nothing loose in the front end. I jacked her up and had no slop in the front wheels, but the RF makes some noise unlocked. Spinning by hand seems to stop when locked.
I am going to drive her to work with the hubs locked and see if it changes things.
For the record I did some search and drive shaft issues were close but I was learning way too much about Aerostars.
just in case you didn't know, there is another search area.
just below all the page #'s where it says "last" near the top right. it says "search this forum" you wont see aerostars and focus's in there.
If you're talking about lubricating the drive shaft with the Smurf-blue Ford grease...while that's a good thing to do, I don't believe it will make the sound you're describing. That sound is usually more of a THUMP when it's popping into the teeth/grooves. I think Shake-N-Bake hit the nail on the head.
BTW, is this while you're towing your fifth-wheel, or while unloaded (or both)?
Honeydew (i think) had a similar issue a few months ago. His was one of the needle bearings, the inner replaceable ones in the front hubs. It would start a vibration when he hit a bump and he'd have to slow way down to get it to stop, then it was fine till another bump.
If you haven't checked/greased those recently, it won't hurt to pull the hub and check and service the needle bearing. Granted it may hurt physically, as the hubs are a PITA to remove in my experience, but it won't hurt the longevity of your truck...
On another note, when I saw the thread title "I hear noises" and saw it was started by TXdoug, I figured it was just normal for you to hear noises.
I need to get those spring pads as well. Is the dealer kit the only option? I hate to drop $50 on plastic parts, but they appear to be made for the job.
Yep, mine was needle bearings. Get under there and with both hands push straight up and down on the front axle u-joints. The passenger side on my truck had significantly more play in the hub than driver's side. This was the side that was bad, needle bearing in the hub was seized up.
I left the house this morning with hubs locked (manual), within a mile she let out 3 good growls. I was looking for a place to park, trailer and all. Stopped and unlocked the hubs, backed up a few feet and went on to work. Not another peep out of her. After we got back home I crawled under and gave them U joints a good shake and sure enough the right side has more slop.
Guess I'll take off tomorrow and deal with it. I need to find the cheat sheet on this repair and decide if I need to let someone else do it. My experience with needle bearings is allot like putting worms back in the can o worms.
This may be one of those combo deals. The spring tip dealys are toast. I imagine that hosing them down with penestratening lubricant may have shut them up for a couple days.
Part number: Ford-C6TZ-3123A or NAPA-B2110
I new those symptoms sounded familiar, thanks for confirming.
Doug, it's not that bad, just understand that it's going to be "welded" to the knuckle and gone need some persuasion. I used an air chisel on the studs to punch them out on Gus, in combination with using the rotor as a slide hammer. I replaced the rotor though.
