351 hesitation
Old Mar 26, 2013 | 09:05 PM
My Good 'ol 92's Avatar
My Good 'ol 92
351 hesitation
Hey fellas! Just picked up a 1994 F150 4x4 with a 351. It runs pretty well, however, when the truck is at idle, and I gas it, it will stumble a little bit before climbing revs. Also sometimes right after i start the truck, it will idle a little rough but if I blip the throttle, it smooths out. Other than that, the truck runs great. New spark plugs, cap and rotor are in pretty good shape. other than that i havent had much time to mess with it. It has 196,XXX miles if that helps any. Any and all help appreciated! Thanks in advance!
Dustin
Old Mar 26, 2013 | 09:26 PM
kegomatix's Avatar
kegomatix
Start with the simple, check the timing.
Old Mar 26, 2013 | 09:29 PM
str8sixman's Avatar
str8sixman
ckeck for codes??
Old Mar 26, 2013 | 09:31 PM
My Good 'ol 92
Thanks for the reply! im going to check that tomorrow as long as i have the time. However, i dont believe that is the problem. The thing runs like a scolded ape other than the problems mentioned. Thats a beautiful 93 you've got there BTW.
Old Mar 26, 2013 | 09:34 PM
My Good 'ol 92
And no I have not yet run it for codes. Can a code show up without the CEL? Thanks for your reply!
Old Mar 26, 2013 | 09:43 PM
kegomatix's Avatar
kegomatix
Thanks. When you check your timing be sure to remove the SPOUT.
And yes, there can be codes without a light so it's always good to check just in case.
Old Mar 27, 2013 | 01:49 AM
pnp522's Avatar
pnp522
I have the same issue with my 93 F-150 5.0. Timing 12 degrees new coil, cap, rotor, wires, and Autolite plugs. No codes either. Step on the gas and it just sits there for a second and then takes off.
Old Mar 27, 2013 | 08:13 AM
str8sixman's Avatar
str8sixman
my 4.9 did that and it turned out to be the throttle body gasket was bad and sucking in
Old Mar 27, 2013 | 08:22 AM
My Good 'ol 92
Alright. Ill run it as soon as i can!
Old Mar 27, 2013 | 10:53 AM
pnp522's Avatar
pnp522
Have replaced all intake gaskets and the IAC also, So it's not that on mine. I will be swapping in a 5.8 for the 5.0 in a couple of weeks. Will see if anything changes since the 5.8 doesn't have that problem in the truck that it's in now.
Old Jul 5, 2013 | 08:58 PM
eriklane's Avatar
eriklane
Try taking the electric choke wire off and see if it's different. Could be too rich. Found that out with mine-and horrible mileage also, removed it and much improved.
Ford4you
38
Mar 9, 2016 07:01 AM
bluethundersowner
Nov 16, 2013 11:24 AM
cpettymore7777
Mar 24, 2011 02:51 PM
BearFootCustom
Aug 1, 2010 09:52 AM
