How many miles before adding DEF
Old Mar 25, 2013 | 09:11 PM
wing_96's Avatar
wing_96
I've got around 5,000 miles on my new truck and haven't added any yet.
I have a couple questions for y'all.
1. Is there any kind of warning before the truck starts running in the reduced power mode (don't know the technical term)?
2. How many miles do you average between adding DEF?
Thanks,
David
Old Mar 25, 2013 | 09:16 PM
2ndStroke's Avatar
2ndStroke
It will tell you in the info screen if you are half full, etc. Under system checks I believe? It will give you several warnings, giving you the chance to fill the def tank before it reduces your speed.
Old Mar 25, 2013 | 11:33 PM
Painted Horse's Avatar
Painted Horse
I check my once a week and when I see it under half full, I add a 2.5 gallon jug.
On average, 5 gallons = 5000 miles, So you are probably getting close to empty. As stated. You will get an 800 miles to empty message that will count down to the reduced power. You should be able to find DEF somewhere in that 800 miles.
Don't be surprised to learn that it takes more than 2.5 gallons to get that 800 miles to empty count down to shut off. You need to get something well above 1/2 full.
Old Mar 25, 2013 | 11:45 PM
JSolve's Avatar
JSolve
Thanks,
David
Hi David and welcome to the forum. Those are both good questions and answered well by the responses. There is a lot of good information in the Diesel Supplement manual on this and other essential topics. It can be downloaded in PDF format from the Ford site. Happy truckin'
Old Mar 26, 2013 | 07:30 AM
WildWildWest's Avatar
WildWildWest
If you live in cold climate you save on DEF in he winter. Topped mine up over 12,000 miles ago in October and still showing under half full. When she's frozen, you don't use much!! Now summer and towing season coming - that will change. Don't worry, you'll be warned several times before you have to worry about the truck going into limp mode. DEF use seems to totally depend on loaded vs. unloaded miles with my truck.
Old Mar 26, 2013 | 07:56 AM
SavageNFS's Avatar
SavageNFS
this...x2
Old Mar 26, 2013 | 08:18 AM
wing_96's Avatar
wing_96
I didn't know that so thank you for letting me know. I will download it today!
Old Mar 26, 2013 | 08:20 AM
wing_96's Avatar
wing_96
I had heard horror stories of people being stuck because they ran out of fluid and had the truck shutdown.
I bought a 2.5 gallon jug that I have in the truck "just in case", but I am glad to know that it will take more than 2.5 to get the level back above the warning stage.
Thanks all!
Old Mar 26, 2013 | 08:43 AM
MYTRUCKNOWRATTLES's Avatar
MYTRUCKNOWRATTLES
I used to carry the 2 1/2 gl jug when I fist got my new truck as I was afraid to get caught running out on a trip. Now like everyone said you will have plenty of warning to refill. Mine will usually will say I have 800 miles left on def. so I know I need to get it filled. I do try to top off after it says under half full and keep trucking. The truck stops are getting more DEF fill stations at the pump so it makes it even easier to keep it full.
Happy trucking
Welcome to the forum
Old Mar 26, 2013 | 09:48 AM
Native Tex's Avatar
Native Tex
Happy trucking
It is a shame that Ford did not put a guage on the dash that would give the information. I would not think it would be that complicated.
Old Mar 26, 2013 | 10:25 AM
lundman's Avatar
lundman
DEF
My 2011 can go about 10 000 kms (6 200 miles) and it is just showing under 1/2 full. So for you mileage of 5 000 I would think you may be about 5/8 full of DEF. I too worried at the beginning but I just get it topped up every oil change.
Old Mar 26, 2013 | 12:51 PM
wing_96's Avatar
wing_96
Happy trucking
Thanks! This place is a great resource for truck owners, and I am glad I found it.
Old Mar 26, 2013 | 12:53 PM
darren32's Avatar
darren32
Welcome to FTE
Old Mar 26, 2013 | 05:38 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Welcome aboard........
My experience has been:
- The more I work the Truck....the more I use.
- The DEF will freeze in the winter, however my owners manual (Diesel Supplement) informs me there is a DEF Heater, so the fluid is used in my truck during the Montana winters.
- It is 1/4th the cost at a DEF Pump at a truck stop compared to the Ford Dealer
- It is 1/2 the Ford dealer cost at Sam's Club or Wal-Mart.
- The Diesel Supplement that came with the Truck has a bunch of very important information.
Enjoy a Great Truck........
Old Mar 26, 2013 | 07:09 PM
gopedoligist's Avatar
gopedoligist
there is a simple solution to all of this.... i change my oil every 5k. when i bring it in for an oil change, they top off the DEF. problem solved
