2003 Tire Pressure Sensor Problem?
Old Jun 3, 2003 | 12:29 PM
dkristja's Avatar
dkristja
Does anybody with a 2003 Expedition have the tire pressure monitoring system? If so, any problems? I have one, and with 3,000 miles on the vehicle, I got a warning that the tire pressure was low. It "bings" about 12 times in a row every minute or so. I checked the tires, and they are fine. Has anyone else had this problem?
Old Jun 5, 2003 | 11:54 PM
ATexasMan's Avatar
ATexasMan
I had mine disabled at the dealership. I swapped out my factory wheels and tires and constantly had error due to transmitter being attached to stem. If you still have original tires check spare. You may need dealership to reset sensors.
ATexasMan's Avatar
ATexasMan
Old Jun 6, 2003 | 07:53 AM
Sturge's Avatar
Sturge
I have a Dodge Intrepid (sorry...the "D" word is probably a bad word around here!). I frequent a similar website as FTE called DodgeIntrepid.net and there are lots of folks who have installed a tire sensor system. I don't have it on my car but there's a ton of info on how the system works and how to troubleshoot. Just use the search function once you get there. Should be a very similar system.
