Crown Vic swap in a 68 questions
Old 03-23-2013, 11:04 AM
BigRobK's Avatar
BigRobK
BigRobK is offline
I'm considering doing the crown Vic front end (disc brakes, suspension, power steering etc...) swap in my 68 f100 and was hoping to some feedback and suggestions so I can start getting a parts list put together and figuring my budget and time. Here are a few questions I'v got so far:
1. is the 03-08 crown Vic the easiest to use or can I go older?
2. If I can use a late 90s donor car how different is the geometry in them?
3. Are grand marquis identical for the parts needed?
4. Are there any other year/model that I can use as the donor? Ie town car LS mustang etc...
5. Any websites or links with pics to read up on?
Thanks,
Big Rob
Old 03-23-2013, 12:45 PM
48prerunner's Avatar
48prerunner
48prerunner is offline
1. can't go older unless you want to sub frame. the later vics are the ones that have the bolt in aluminum cross members.
is same.http://en.wikipedia.org/wiki/Ford_Crown_Victoria and http://en.wikipedia.org/wiki/Mercury_Grand_Marquis; both models also used the http://en.wikipedia.org/wiki/Ford_Panther_platform
link https://www.ford-trucks.com/forums/7...o-67-f100.html
Last edited by 48prerunner; 03-23-2013 at 01:05 PM. Reason: had to look for link might be what gembone posted
Old 03-23-2013, 01:00 PM
Gembone's Avatar
Gembone
Gembone is offline
lots of build here on FTE and on Fordification that go through the IFS CV swap.
Here is a link to some very helpful resources.
Linky
Old 03-23-2013, 07:06 PM
BigRobK's Avatar
BigRobK
BigRobK is offline
I'm having a hard time seeing some of the pictures. I'm using safari on my iPad. Any suggestions
Old 03-23-2013, 07:24 PM
48prerunner
think some of the pics so old the links don't work anymore I emailed you a better link but not on this forum.
Old 03-23-2013, 07:29 PM
BigRobK's Avatar
BigRobK
BigRobK is offline
Great thanks
Old 03-24-2013, 06:36 AM
Area351's Avatar
Area351
Area351 is offline
I just did the swap in my 67 and used an 05 CV Police Interceptor as a donor.
If you have any specific questions, let me know.
In a nutshell, you cut out all the old suspension and brackets (hardest part), drill 14 holes and fab up some lower trailing arm brackets.
You then need to adapt your steering column to the CV rack.
Pretty simple.
Old 03-24-2013, 06:38 AM
Area351's Avatar
Area351
Area351 is offline
You also need to cut some pipe to use as spacers where the 4 bolts go through the frame. I used 3/4" schedule 40 black pipe. They prevent the frame from collapsing when you tighten the bolts.
I would also recommend boxing the frame area as well.
You also need to fabricate some motor mount brackets.
Old 03-24-2013, 07:49 AM
BigRobK's Avatar
BigRobK
BigRobK is offline
Great feedback thank you. This is exactly what I was going for you guys are awesome!
caravaggio2000
17
04-06-2018 08:53 AM
AliceSML79
04-24-2017 11:34 AM
Andy1966
09-11-2014 11:57 PM
Haastyle
03-07-2011 06:32 AM
moonlightdriver
13
07-04-2007 06:08 PM
Quick Reply: Crown Vic swap in a 68 questions
