223 I-6 Oil Cap
Old 03-24-2013, 09:09 AM
Steves55's Avatar
Steves55
Steves55 is offline
223 I-6 Oil Cap
Are the oil filler caps on the 223 I-6 supposed to fit snug? Although mine does not come off on its own, you can move it back and forth very easily. It may explain why I'm getting oil sling under the hood. Thanks. Steve
Old 03-24-2013, 09:15 AM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
The filler cap should fit so tight that it does not fall off when the truck hits extreme bumps. Oil slinging under the hood is most likely blow by and not the fault of the filler cap.
Old 03-24-2013, 09:48 AM
Steves55's Avatar
Steves55
Steves55 is offline
Thanks. I may fiddle a bit with the cap and see if I can get it more snug. With regards to blow-by, anything I can do to setlle that down or is it just nature of the beast?
Old 03-24-2013, 10:21 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Just the nature. I recently had my 215 engine rebuilt and while it was running yesterday, I noticed some blow-by.
Old 03-24-2013, 10:24 AM
Steves55's Avatar
Steves55
Steves55 is offline
That's what I thought too. I guess that's what the blowby tube is for. By-the-way, with the help of my trusty hammer, I bent down the oil cap ears a bit and now get a good firm fit when I installed it.
derek0525
20
03-06-2018 09:17 AM
Boondockdad
04-25-2016 10:33 PM
bigunit54
2004 - 2008 F150
12-04-2013 05:25 PM
haulingboat
11-04-2008 05:54 PM
ckal704
04-19-2006 10:59 AM
Quick Reply: 223 I-6 Oil Cap
