Instrument cluster diagram
I am not sure about an 03 but the newer clusters do more than display
data. They also control things like the delay power relay and even have
a link with the communication buss (DTC if I recall right). The Ford wiring
diagran won't do you much good. It does not give any info about the internals
of the cluster. I think your going to find even on you 03 that there is a lot of
things going on behind the displays.
I think it would be real cool to have an all electronic display cluster that you could
adjust to display other data.
Sean
Sean
depending on the truck year and model you can normally find diagrams here https://www.fleet.ford.com/maintenan...ls/default.asp I have for the 09 a few times. might be worth a shot checking out
finneys98xj
WTB - Ford Trucks & other vehicles
04-29-2012 07:16 PM
