7.3 swap
Old Mar 23, 2013 | 03:37 PM
Pequeaford's Avatar
Pequeaford
7.3 swap
Hey y'all. Would a 7.3 idi fit in a 02 f250 that's got a 7.3 powerstroke. The powerstroke that's in it has a cracked block
Old Mar 23, 2013 | 03:41 PM
BillyBob69's Avatar
BillyBob69
What year is the donor from? For the most part...yes. Should bolt right up.
Old Mar 23, 2013 | 03:46 PM
Skip1970's Avatar
Skip1970
thats a very good question! i wonder if it would, i know with a welder and cutting wheel anythingll fit anything.
i got a 5.4 sd im gonna yank that junk out and put a 460 or idi in it, cause thats what i got. if i had my dream engine i would put a 300 inline 6 but i aint got one or the money to get one.
Old Mar 23, 2013 | 03:54 PM
JOHN2001's Avatar
JOHN2001
Sell both and put a 12valve cummins in it
Old Mar 23, 2013 | 04:15 PM
Skip1970's Avatar
Skip1970
dont need no over rated junk save them for the kids to impress their ignorent friends with.
Old Mar 23, 2013 | 04:23 PM
Franko72's Avatar
Franko72
Molon Labe
That or a 24 valve. An IDI would be a big step backwards.
Old Mar 23, 2013 | 04:40 PM
Pitcrw6's Avatar
Pitcrw6
An IDI is a dog of a motor but a good dog. It would be tough for it to get out of the way of its own shadow.
Old Mar 23, 2013 | 06:11 PM
JOHN2001's Avatar
JOHN2001
Call it what you want b-uno.....
The 12 valve is simple to drop into just about anything not to mention can make good power. Someone makes and adapter plate to adapt it to the 4R100. It only needs one wire hooked to it to make it run that's why I said 12 valve and not 24 valve... Much simplier swap and can be had cheaper also.
Old Mar 23, 2013 | 06:33 PM
tjc transport's Avatar
tjc transport
i ain't rite
that gold plated slug may be cheaper to buy, but the IDI stock without a turbo has more HP and torque, and will not cost you $6000 for motormounts and trans adapter plate.
Old Mar 23, 2013 | 06:55 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
it would be a fairly issue free swap one would think for the budget minded.old school simplicity is sometimes all ya need.
if it means running an idi or scrapping the truck,set the idi in there and run 'er for all she's worth if you don't need to pass smog.
Old Mar 23, 2013 | 07:47 PM
BigBlockF350's Avatar
BigBlockF350
Sounds like a cool swap. I love the old IDIs. Subscribing to this thread!
Old Mar 24, 2013 | 01:59 AM
Pequeaford's Avatar
Pequeaford
The body is an 04 sorry for screwin that up. I dont know if it changes anything and I don't know what year the idi is from. A guy I work with has 4 just sittin around. I was just wondering if it'll fit in the 04 body and bolt up. I also have a friend that's got a 93 with a 7.3 idi and he's got nothin bad to day about it. So before I said anything to the guy I work with I wanted to no if it'll even fit. And I'm from PA so screw that smog stuff I just can't roll alot of coal. The po po don't like not bein able to see. And cummins may have alot of torque but they sound like a dieing cow.
Old Mar 24, 2013 | 04:28 AM
tjc transport
i ain't rite
the only issue i can see having is if it has an automatic trans you may have an issue with tach signal to the computer for proper trans function.
and a lot less power than the 6 liter.
Old Mar 24, 2013 | 05:45 AM
Pitcrw6's Avatar
Pitcrw6
You can make anything fit with time and money. Are you in a hurry to get this done or is it a project truck? I dont see any of the 6.0 stuff hooking right up to the IDI and working correctly.
Old Mar 24, 2013 | 06:47 AM
Crewcab Turbo's Avatar
Crewcab Turbo
You will need a transmission along with the IDI engine because the IDI will not bolt up to the Superduty 5r100 transmission.
