Transmission ID
Old Mar 23, 2013 | 12:33 PM
truckief350's Avatar
truckief350
Transmission ID
Hey all,
I'm working with a 74 f350 chassis-cab that needs a transmission rebuild.
Is there someplace in the vin to look to see what stock trany model came in this truck? The door plate has a "transmission code" of 27j
Privateer indicated this meant it was a Dana 70 with 4.10s and power steering.
The trany is a 4 speed, reverse is to the right and down, and the truck is a 2wd dually.
I have a casting number and the vin if that helps:
casting no: 13894
vin: f37mku01242
so far the vin decoding i've been able to get to online says cab and chassis with a 390 and a 4bbl built in KC, Missouri. Most all the vin decoding sites don't deal with trucks this old... I know with my 01 dodge I went in to the dealership and had them look the truck up in their computer. Is this possible with something this old?
Thanks!
Charlie
Old Mar 23, 2013 | 12:48 PM
montana_highboy's Avatar
montana_highboy
It's most likely a NP435
Manual Transmission Identification Guide - FORDification.com
Old Mar 23, 2013 | 12:50 PM
redroad's Avatar
redroad
more info here also https://www.ford-trucks.com/forums/1...ml#post1332627
Old Mar 23, 2013 | 02:05 PM
truckief350
Thanks for both links.
I had found and read them before. Based on the trany ID guide I had guessed it was the New Process trany as well, but I wasn't the one who crawled under and got the casting number, so...
And as far as the vin decoder goes, it appears the one functional link there is for decoding newer vehicles...
C
Old Mar 23, 2013 | 03:12 PM
fordman75's Avatar
fordman75
Most likely a NP435 or a T-18/T-19
The NP 435 will have an aluminum top plate/shifter tower. The T-18/T-19 would have a cast iron top.
The other difference is how the shifter is held in. The NP435 will have a retainer cup that you have to push in and twist to release. The T-18/T-19's will have a cup that has threads and just unscrews.
Old Mar 23, 2013 | 07:54 PM
1975MudRat's Avatar
1975MudRat
If the reverse it toward the seat its a Np-435 and if its toward the dash its a T-18
Old Mar 23, 2013 | 08:34 PM
montana_highboy
The later T-18's had the same shift pattern as a NP435 (reverse towards seat) in 78 and/or 79 i think, but this shouldn't be the OP's case unless there was a tranny swap.
Nattycakes
Mar 29, 2017 02:10 PM
Jimbog
Large Truck
16
Jun 23, 2013 04:00 PM
Bigct59
Large Truck
Jul 19, 2010 05:00 PM
Rusty_Old_F250
Oct 16, 2009 11:55 PM
nickc84
Oct 3, 2000 06:23 PM
