Sponsored by: Real Truck
dipstick
Old Mar 22, 2013 | 06:34 PM
Vinford's Avatar
Vinford
dipstick
2005 F-350 4x4
5.4 engine.
180,000 miles.
Anyone know what would make the dipstick blow out and sray oil everywhere?
Old Mar 22, 2013 | 06:57 PM
Tom's Avatar
Tom
Originally Posted by Vinford
2005 F-350 4x4
5.4 engine.
180,000 miles.
Possibly a plugged PCV valve?
Old Mar 22, 2013 | 07:25 PM
JWC 3's Avatar
JWC 3
Excessive crankcase pressure . If in BC , cold climate . Ck for frozen crank vents and pcv system . Moisture can collect and freeze vents and pcv systems . If you have the heated pcv system , ck that it has proper flow of heated coolant to it . If yours does not have one , It may be an upgrade that is available .
Old Mar 22, 2013 | 10:47 PM
Yahiko's Avatar
Yahiko
After the up-above things broken ring can do that or hole in the piston.
Not happy things to have to thing about. Do a leak down test on it.
If you find one that is leaking a lot then there is you problem.
Sean
Old Mar 23, 2013 | 07:12 AM
2000silverbullet's Avatar
2000silverbullet
Am I the only one that reads the title of this thread in my head in a Roscoe P Coltraine voice?
Old Mar 23, 2013 | 10:18 AM
m.qualls89's Avatar
m.qualls89
Now your not lol
Old Mar 23, 2013 | 09:03 PM
Vinford's Avatar
Vinford
Sean
Looks like its something serious, Im not at truck im getting info over the phone.
theres already been a motor replaced I think this truck is going to go to the big steel pile in the sky..................or wherever POS trucks go!
Old Mar 23, 2013 | 09:23 PM
Yahiko's Avatar
Yahiko
It's always a sad day with you have to put a faithful truck/car to sleep.
Now the junker that is and always has cost an arm and a leg that is a
different story.
On this one you could just drop in a used motor and sell it to get some $$ back out.
If the body is good and the only problem is the engine.
Just a thought.
Sean
Old Mar 23, 2013 | 11:55 PM
Vinford's Avatar
Vinford
different story.
Just a thought.
Sean
I was buying it and the price was just OK.
But without a engine it turns things around the guy wants the same price because its got a nice factory flatdeck on it and some nice tires.
He says the value is still there but to me it snt by the time I put another engine in it.
To bad, its not a bad looking truck.
Old Mar 24, 2013 | 12:06 AM
Yahiko's Avatar
Yahiko
I guess he gets to keep it. I would like to know where he finds value in that.
Good luck hunting a nice one down. There out there.
Sean
Old Mar 24, 2013 | 07:17 AM
Tom's Avatar
Tom
You're condemning the truck simply because there's a chance it would need a new engine? How 'bout some diagnosis first? A clogged PCV system could cause the same thing and cost $10 to fix!
Old Mar 24, 2013 | 03:30 PM
Yahiko's Avatar
Yahiko
Tom's right I gave the worst case scenario because the
simple fixes were already listed. Check it out with a good diagnosis.
May be the $10 fix is what you need.
Sean
juchertf100
Aug 23, 2010 08:26 AM
james gang 1001
May 22, 2006 12:25 PM
derherr65
Jan 15, 2006 04:15 AM
jenkinsj
Nov 26, 2005 09:01 PM
