Interior trim
Old Mar 22, 2013 | 05:21 PM
Buzzard47's Avatar
Buzzard47
Interior trim
I don't know the specific name for the trim but it is the trim that runs across the dash and onto the doors. How do you take that trim off the doors?
Truck is a 1992 f150 xlt
Old Mar 22, 2013 | 05:22 PM
Diesel_Brad's Avatar
Diesel_Brad
You dont. It is part of the door panel. Once you take it off, you break the ONE TIME plastic **** that are there. Then you will be gluing the trim back on
Old Mar 23, 2013 | 11:50 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
You can remove the door panels, remove the backing and then gently pry up the tips with a pair of pliers. the pieces are plastic on the dash but metal on the doors. Be careful as although the tips are metal, you can break them off if you move them around too much.
Old Mar 24, 2013 | 12:07 PM
joshh's Avatar
joshh
Both of u are right. What color of moulding is it ? There is a metal one and a plastic one. The plastic one is melted to the door panel ( like a plastic spot weld )
Old Mar 24, 2013 | 04:54 PM
f1504x4driver
Proud Pirate
the trim strip that runs across the dash and on the doors is metal on the door. The tabs are small square metal ones that are pushed down to hold the trim on the door panel. Take a pair of pliers and raise the tabs and then you can remove the trim strip. If you have an XLT the strip is usually silver but can be black.
RL250
Apr 27, 2020 10:00 PM
alecs
Jul 5, 2019 03:43 PM
LARIAT 85
18
Mar 16, 2010 12:02 PM
kupiec20
Dec 18, 2007 07:38 PM
