Running Ethanol
Old Mar 22, 2013 | 03:17 PM
hoerigb's Avatar
hoerigb
Running Ethanol
Curious if anybody else is running on ethanol?
I have an 07 5.4 flex fuel and did an experiment for one of the classes that I teach. I drove 10 tanks gas, kept track of mileage and cost. Got about 16 mpg Then I switched and started driving on ethanol. I have been getting only 12.5 mpg. I knew there was going to be less but this was way less. I still have a few more tanks to go through before I finish the experiment and calculate the cost between the two. I have been getting E-85 for $3.29. Gas now is 3.85.
Also, did an experiment testing emissions as well. Ethanol produces far less CO2 and emissions. And my exhaust smells like moonshine.
Old Mar 22, 2013 | 10:39 PM
Schiben's Avatar
Schiben
How much is "far less" CO2 and emissions? Is that or is that not considering that ~1/3 more fuel is being used? Keep us up to date.
Old Mar 23, 2013 | 07:03 AM
hoerigb's Avatar
hoerigb
The ethanol produced about half as much CO2 as the regular gas. So when you figure out how much is used per mile its about 1/3 less overall.
Old Mar 25, 2013 | 10:10 PM
makidog's Avatar
makidog
One thing I've noticed running E-85 in a 2008 is that the mileage drop is not linear based on percentage of alcohol in the tank. If I fill the tank holding gas at half empty with E-85 (essentially mixing to make roughly E-50) there is not much of a drop in mileage. When you reach higher concentrations of E-85 in the tank the mileage really dives. Something to do with the engine management software/monitoring I imagine.
I watch mileage in realtime using a Scangauge II hooked to the OBD port. Since I tow and haul stuff long distances I've been able to save a chunk on fuel this way plus I have the optional large cap tank and sometimes carry a portable 30 gallon to take advantage of low gas/E85 prices I come across.
2011FX2Crazy
2009 - 2014 F150
112
Aug 8, 2015 01:50 AM
Club Wagon
1997 - 2003 F150
Oct 5, 2012 07:43 PM
MikeB 88
General Automotive Discussion
24
Jan 14, 2009 08:43 AM
mikecox1
Apr 14, 2008 05:15 AM
elite64a
2004 - 2008 F150
13
Feb 2, 2006 11:19 AM
