VERY disappointed in my trucks towing capacity.
When i tow with my dent i drive 55 no matter what the speed limit is. Even through school zones...just kidding.
To tall a tire and wheel combo will negate any improvements made by lower gearing. You can tow with a dent. You just need to think by 1970's standards. Unless you want to invest a whole lot of capital to make it like a newer truck. and by then you could have bought said truck.
I have a 74 F350 w/460, 4bbl.,C6, 4.10 all stock and dual exhaust and 43K original miles. It has a lot of power and torque but I think the reason you feel like you have to "push" it is because of the basic set up of the 3 speed auto and 4.10 axle. It also hauls, on occasion a 3K slide in camper. I won't go more than 60 tops on the highway, empty, since it feels like the RPM's are too high and you have to push it. I had a 72 F250 w/390, 2bbl, C6 and 3.73 axle and it could cruise a little better on the highway but it didn't have quite the brute power of the 460. You may also feel a little frustrated because you might be comparing it and expecting similar performance to a newer truck. We tow a 6K trailer with our GMC Denali XL w/6.0 L Vortex. If you are expecting similar performance at highway, towing as a newer truck, it just won't happen. Night and day difference and unless you make a ton of modifications to the engine and install a gear vendor overdrive unit, it wont compare. I like our Denali as a daily driver, but I LOVE my F350 for what it is and won't make any modifications to it. BTW, your truck looks awesome!
For instance, a 10-speed bicycle. You start with the small gear on the rear axle and as you increase your speed, you are able to switch to the larger gear. But, remember what it was like if you forgot to switch gears back and tried to start on the larger gear. It made it very hard to say the least.
Lower gears = (numarically higher)
Example (ignore the math, if you choose, and go straight to the bolded text):
Say you have 100 ft/lbs of torque at the driveshaft and 4.10:1 gear ratio; you'd have 410 ft.lbs. of torque at the wheels. Say your tires are 28" now...
28/12/2= 1.16 foot wheel radius
410/1.16= 353 lbs of force applied to the ground
Now, pretend that you switch to 4.56:1's and 33" tires.
100x4.56= 456 ft.lbs.
33/12/2- 1.375 feet
456/1.375= 331 lbs of force
Hey, lookie there! You geared down and slapped some bigger wheels on your rig and now it's even more underpowered!
@devino246 and the motor is running at what RPM ?
"(ignore the math, if you choose, and go straight to the bolded text)" @65mph
<table bgcolor="#eaeaea" cellpadding="0" cellspacing="0" width="700"><tbody><tr><td bgcolor="#FFFFFF">3.31
</td> <td bgcolor="#FFFFFF">3.42
</td> <td bgcolor="#FFFFFF">3.55
</td> <td bgcolor="#FFFFFF">3.73
</td> <td bgcolor="#FFFFFF">3.91
</td> <td bgcolor="#FFFFFF">4.11
</td> <td bgcolor="#FFFFFF">4.27
</td> <td bgcolor="#FFFFFF">4.56
</td> <td bgcolor="#FFFFFF">4.88
</td> <td bgcolor="#FFFFFF">5.13
</td> <td bgcolor="#FFFFFF">5.29
</td> <td bgcolor="#FFFFFF">5.38
</td> <td bgcolor="#FFFFFF">5.71
</td> <td bgcolor="#FFFFFF">6.17
</td> <td bgcolor="#FFFFFF">7.17
</td><td valign="top">
</td></tr></tbody></table> <table bgcolor="#eaeaea" cellpadding="0" cellspacing="0" width="700"><tbody><tr><td bgcolor="#FFFFFF">28"
</td> <td>2582
</td> <td style="background-color:#990; color:#fff; font-weight:bold;">2668
</td> <td>2769
</td> <td style="background-color:#F90; color:#FFF; font-weight:bold;">2909
</td> <td>3050
</td> <td style="background-color:#F00; color:#FFF; font-weight:bold;">3206
</td> <td>3331
</td> <td>3557
</td> <td>3806
</td> <td>4001
</td> <td>4126
</td> <td>4196
</td> <td>4454
</td> <td>4813
</td> <td>5593
<table bgcolor="#eaeaea" cellpadding="0" cellspacing="0" width="700"><tbody><tr><td bgcolor="#FFFFFF">33"
</td> <td>2191
</td> <td>2263
</td> <td>2349
</td> <td>2469
</td> <td style="background-color:#990; color:#fff; font-weight:bold;">2588
</td> <td>2720
</td> <td style="background-color:#F90; color:#FFF; font-weight:bold;">2826
</td> <td>3018
</td> <td style="background-color:#F00; color:#FFF; font-weight:bold;">3230
</td> <td>3395
</td> <td>3501
</td> <td>3561
</td> <td>3779
</td> <td>4093
</td> <td>4745
Green = Best MPG, this is what you would want to get for the best fuel economy and highway cruising
Orange = Best Overall, this is good mix of power/MPG and considered best for daily driving.
Red = Best Power, this will give you the best performance for towing power, but at the expense of your MPG.
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
^^^agreed. You can change all the numbers but you have to figure in the now also changed engine performance. There are so many variables, why even discuss that?
Don't forget, when these came out the max speed limit was 55?? As has been mentioned, to get the higher speeds, lots of things have changed in trucks. Upgrades will get you there, but not very cheap or easy.
At 55mph w/4.10's and 28's,
(1.16x2)3.1415 = 7.28828 foot wheel circumference
5280x55= 290,400 feet per hour
290,400/60= 4,840 feet per minute
4,840/7.28828= 664.07986 axle RPM
664.07986x4.10= 2,722.72744 RPM... just don't forget to factor in torque converter slip
At 55mph w/4.56's and 33's,
(1.375x2)3.1415 = 8.639125 foot wheel circumference
4,840/8.639125= 560.24192 axle RPM
560.24192x4.56= 2,554.70316 RPM
</td> <td>2582
</td> <td>2769
</td> <td>3050
</td> <td>3331
</td> <td>3557
</td> <td>3806
</td> <td>4001
</td> <td>4126
</td> <td>4196
</td> <td>4454
</td> <td>4813
</td> <td>5593
</td> <td>2191
</td> <td>2263
</td> <td>2349
</td> <td>2469
</td> <td>2720
</td> <td>3018
</td> <td>3395
</td> <td>3501
</td> <td>3561
</td> <td>3779
</td> <td>4093
</td> <td>4745
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
#29
#30
