Carb selection
Old Mar 20, 2013 | 11:52 AM
rdweathers's Avatar
rdweathers
Carb selection
I have a 390 with mild cam finally running correct, it had a Holley 600 that has non adjustable floats on it that has been a problem child since new. I have a holley 770 street avenger on the motor from another vehicle now and it runs 100% better. So i am in the market for a carb. What are the opinions for which brand carb to use? The holley 770 needs to go back on the motor it came from.
Old Mar 20, 2013 | 12:27 PM
redroad's Avatar
redroad
This always starts a huge discussion on Edelbrock vs Holley .. Love the Edelbrock 1406 on my 390 highboy .. Also tuned a 1405 to get 12mpg on a F250 2wd with a C6 .. Always had good luck and low maintenance on that Carter AFB style carb on a 390 truck ..
Old Mar 20, 2013 | 12:41 PM
hotstuff's Avatar
hotstuff
And so it starts . I like my HOLLEY , Ford put them on there trucks for a reason .They can be tuned in and the parts are every where
Old Mar 20, 2013 | 12:54 PM
redroad's Avatar
redroad
Are you kidding that's your argument
your going to have to better than that ..
The power valve alone pre 92 is a show stopper
Old Mar 20, 2013 | 01:05 PM
AK FORD GUY's Avatar
AK FORD GUY
I have read pretty good things on the Quick Fuel Technology (QFT) carbs.
They are a little pricey, but I purchased a SS-680-VS for my build. They also make some more inexpensive models, but they have cast metering blocks instead of the billet metering blocks the SS Series uses.
HIO Silver's Avatar
HIO Silver
Oh boy.. here we go. IMO, Holleys tend to be fussy.
My all time favorite is the Autolite 4100. Look for a 1.12 casting within the clock face cuz it's 600 cfm. $40 to $60 at a swap meet. Easy to rebuild and really easy to tune. Works like a champ.
In modern terms, I'd go with a 600 cfm Edelbrock 1406 for a daily driver
-OR-
Summit's branded clone of a Holley 3310 in 600 cfm. They're like $235 right now.
Old Mar 20, 2013 | 01:12 PM
ibleedblue1385's Avatar
ibleedblue1385
I put a 750 vac. secondary summit racing carb on my 400 about a year ago and i love it.
Old Mar 20, 2013 | 01:20 PM
redroad's Avatar
redroad
For the record on my 460 rebuild I probably will use a Holley with vaccum secondaries , which BTW is all done except the carb so I'm open to persuasion
Old Mar 20, 2013 | 01:42 PM
hotstuff's Avatar
hotstuff
Not to argue , but who is still making carburetors ? From 1909 till today, I'll say thats a long record for HOLLEY
Old Mar 20, 2013 | 05:04 PM
jim collins's Avatar
jim collins
Okay , I'l jump in here too.I'v got an old 80s era Edelbrock 1406 on my 302. I'v used it on a lot of different engines from 289,302 ford to a 4.3L chev v6 and 350 chev . I put a kit in it every so often , depending on how much it's been used . Then it's ready to go again trouble free with just a little tuning for which ever engine i have it on. I picked up a Carter AFB a few months ago and rebuilt it with a missing chock plate and it starts right up after three pumps on the pedal in 30 degree weather. Never had a holley that never needed a lot of tuning , then they leak gas plus power valve problems . I think it comes down to what you like as they all can be good or bad . My $.02 or less worth.__
Old Mar 20, 2013 | 05:30 PM
rdweathers's Avatar
rdweathers
I have always had holleys, but this last one with non adjustable floats has always had problems with flooding, it would alternate between the front and back bowls. Very agravating and this has got me thinking of something different. I have always known the power valve issue - one back fire and plan on replacing it. Thanks for all the thoughts.
Old Mar 20, 2013 | 05:48 PM
tater_51's Avatar
tater_51
Autolite
AUTOLITE....I'm running a 4100 on my Bronco and have another one ready to go on my 416 F100. As HIO Silver mentioned they are cheap and easy to rebuild/tune. I had to rejet the one on my Bronco but they take Holley jets so there's no problem in tuning for your application. Lots of information on-line.
Old Mar 22, 2013 | 10:41 AM
wdfp's Avatar
wdfp
When I get the chance I want to try that new 625 demon that looks like they couldn't decide between a 3 and a 4 bbl. I think it shows some promise in simplicity..
Old Mar 22, 2013 | 11:50 AM
AK FORD GUY
If I remember correctly, not all of them take the Holley jets. Some take a Motorcraft/Autolite jet and they are harder to find and expensive when you do.
I have an Autolite 4100 1.12 with a fresh rebuild, I was thinking about putting it on my 76 F250 with a stock 460.
Old Mar 22, 2013 | 01:30 PM
tater_51's Avatar
tater_51
Here's a good website for autolite information. Last Autolite I picked up came off a 63' galaxie 390 4 speed. I figure the jetting and boosters will be close to what I want.
Ford and Mustang Autolite 4100 carburetors
This info is from the following forum, also a great Autolite source:
Ed's Carburetor Forum. Carbs rule!!!!
The older 4100's and 2100's 64 and down used Holley jets.
The late 64 and up Ford carbs used Autolite size jets.
You can adapt the later carbs to use Holley jets by using a thread insert or reducer bushing.
