NEED HELP
Old Mar 19, 2013 | 03:41 PM
fatfenders56's Avatar
fatfenders56
NEED HELP
I just got my new 351-c fired and it appears to be pumping fuel back from the carb toward the fuel tank. This may sound dumb but the feed from the tank goes to the forward fitting on the pump (fitting for a hose and clamp) and the rearward fitting (with the 5/16 inverted flare) should go to the carb. Is this correct? Sure seems like it should be.
Old Mar 19, 2013 | 04:41 PM
fatfenders56
For anybody who reads this, we found the internal check valves in the fuel pump are sticking and allowing the fuel pressure to feed back to the tank. I disconnected the fuel pump, filled the float bowls with gas and it runs perfectly. New fuel pump will be here tomorrow Thanks anyway
Old Mar 19, 2013 | 06:38 PM
bk53's Avatar
bk53
glad you are on your way
wagonerkl
17
Nov 24, 2017 08:49 PM
Croskey2010
Aug 6, 2017 04:49 PM
jawroper
May 26, 2015 04:29 PM
86ford302help
Oct 4, 2013 09:03 PM
JohnDigger
Jun 15, 2013 12:35 PM
