1967 4 speed shifter
Old Jun 2, 2003 | 09:05 PM
timothy1's Avatar
timothy1
I have a problem with the ball on the pivot part of the shifter the grove is all worn out on the driver side. Both of the pins are still OK. I have tried to find a used one at MANY wrecking yard's but they are pretty reluctant about selling a part to a working trans, and the non working trans haven't been the correct trany. I have been told to weld the ball and then file the grove out, this would be fine if I happened to have access to a welder or a torch to braise it (which I was told was better). I read that there were several people that swaped tranys with newer one's do you still have the shifter's. I have a grany low 4 speed.
