Door Handle Snapped Off?
Old Mar 18, 2013 | 07:02 PM
Kingkong0192's Avatar
Kingkong0192
Originally Posted by ReBilld
Yep, the 80s handles are metal. They do bolt right up. If you shine a flashlight back through the fuzzy stuff around the hole that the handle goes in, you'll see the bolt still holding the broken piece in there.
Thank you sir.
What model 80s handle do i need? Any link?
I thought this one was going to cost me big time.
Old Mar 18, 2013 | 08:23 PM
drtman2's Avatar
drtman2
awesome stuff
Old Mar 18, 2013 | 10:38 PM
ReBilld's Avatar
ReBilld
Here are some, or you can check any junk yards in your area.......INSIDE INTERIOR DOOR HANDLE FORD TRUCK 80 86 RIGHT | eBay
Old Mar 19, 2013 | 06:19 PM
mjunk1's Avatar
mjunk1
This thread is really funny...thanks for the laugh!
Old Mar 19, 2013 | 09:49 PM
Potlicker David's Avatar
Potlicker David
same thing happened to me a while back. A nut driver is all i needed to fix it. I got the chrome handle from carquest. The driver and passenger sides are different so dont get the wrong one. It will look just like the old one but shiny lol
Old Mar 25, 2013 | 02:42 AM
maverick1701's Avatar
maverick1701
Originally Posted by Ford4Life7.3
Your better off replacing them with the chrome metal door handles from 80's trucks. Never break em again.
^ this!
If you break one, the cable is probably already stretched and you keep breaking the plastic handles. On my old OBS, after breaking several plastic handles, I upgraded to a metal handle off an older truck and problem solved
Old Mar 25, 2013 | 04:09 AM
Copedawg's Avatar
Copedawg
Mine broke ALL the time. Finally I replaced the door hinge pin (Tack Auto) and I haven't had a problem since!
Old Mar 25, 2013 | 09:24 PM
stevorino's Avatar
stevorino
Since these guys have confused the snot out of you, let me offer my advice by way of experience. Take the door panel off and check the sheet metal holding the handle mechanism to the door. If it is torn, rivet it or use a fender washer through the mechanism to keep the sheet metal from tearing even more. If the sheet metal is not torn then your cable to the latch mechanism is stretched out and you need to replace it. This is truly a PIA to do but can be completed and the rewards are great every time the door opens like it is brand new. A stop gap solution that might work for a while is to twist the door cable to shorten it up, but in my experience, it doesn't help much. If yo think you are going to replace your door handle and be done with it, I have the receipts for 8 handles that say this won't be your last.
akuhr93'f150
16
Jul 23, 2015 03:22 PM
bxrs52
Nov 10, 2014 11:20 AM
tcoates
Mar 4, 2009 05:43 PM
Gary (UT)
1978 - 1996 Big Bronco
Dec 21, 2004 09:38 PM
bluecloud
Paint & Bodywork
Sep 6, 2004 12:29 AM
