Engine sputtering and missing while accelerating
Old Mar 18, 2013 | 03:05 PM
Javerette's Avatar
Javerette
Hello guys I'm new here but I don't know where else to turn.
I'm not a mechanic professionally but I can fix pretty much anything that goes wrong with my truck so I guess in other words I know my way around an engine. I have a 1991 f150 with a 4.9 straight 6 in it. I recently bought it knowing it needing some work so I wasn't surprised to find it had more problems that originally expected. My problem is that when cranking an driving the engine shakes an sputters violently and it has trouble cranking when cold. I have replaced the fuel pump, filter, relays and fuel pressure regulator... The plugs and wires and the ignition coil, the alternator and radiator. I am at a complete loss. I've done everything short of replacing the fuel rail and injectors. After driving about half a mile the sputtering will let up a little but it will still sputter with hard acceleration. It feels like while driving that the fuel lines have air in the system. That's just a guess however.
I appreciate any help you can give me
Thanks
Old Mar 18, 2013 | 04:32 PM
Bob Gervais's Avatar
Bob Gervais
Sounds like an ignition issue. Check timing and adjust if necessary. Have you checked for computer codes?
Old Mar 18, 2013 | 05:50 PM
Javerette's Avatar
Javerette
I haven't checked the codes not really sure how. The local parts house said they couldn't cause it was to old. I had my mechanic check the timing and he says its fine. That's what I'm saying every obvious fix has either been fixed or ruled out.
Old Mar 18, 2013 | 06:08 PM
White 97 xlt's Avatar
White 97 xlt
Here's how! Fuel Injection Technical Library » How To Run a Self-Test
Old Mar 19, 2013 | 12:02 PM
cwelchy's Avatar
cwelchy
Double check that your spout connector is in place. I had a smog tech remove it and not put it back. Truck started running really weird.
mphurlbert
Oct 3, 2014 07:04 PM
Javerette
Mar 18, 2013 04:02 PM
JimmysRed150
General Automotive Discussion
Sep 21, 2008 07:25 AM
ptesmoke
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
15
Aug 11, 2008 11:24 PM
