1997 F250 problems
Old 03-18-2013, 08:04 AM
Jerrywgroah's Avatar
Jerrywgroah
Jerrywgroah is offline
1997 F250 problems
I am having problems with my 1997 F250 heavy duty truck. Rats chewed up my injector wiring to injectors # 3 & 4. I have repaired the places chewed and reinstalled the wiring.
But, now when I start it only injector # 6 is firing. Injectors # 1 & 5 do not exhibit any firing. These are the only injectors that I can get to with the upper manifold installed. The engine appears to be running on only 4 cylinders.
I did drive the truck several miles with the bad wiring. Could this have fried the computer?
Thanks, Jerry
Last edited by Jerrywgroah; 03-19-2013 at 07:33 AM. Reason: wrong designation of truck
Old 03-18-2013, 07:54 PM
Immortal_Ben's Avatar
Immortal_Ben
Immortal_Ben is offline
If you do indeed have the 97 Super Duty and not the 97 Heavy Duty, then your post is in the wrong section. I suspect it will be moved before too much longer.
Old 03-19-2013, 07:26 AM
Jerrywgroah
F-250 problems
I am not sure where it should be posted or I would move it myself.
I have now changed the type of truck. What is the difference anyway?
Thanks, Jerry
Last edited by Jerrywgroah; 03-19-2013 at 07:36 AM. Reason: wrong descripition of truck
Old 03-19-2013, 07:58 AM
subford's Avatar
subford
subford is offline
I guess Jerry is right, smaller trucks (F250) like yours did change from the OBD-I in 1997.
73fan
15
07-14-2015 12:22 PM
kbarbee95
11-04-2014 09:22 PM
JWGJR_H
1997 - 2003 F150
10-31-2012 05:26 PM
mongo12
10-09-2010 07:20 AM
mike240zt
12-30-2004 04:35 PM
Quick Reply: 1997 F250 problems
