Sponsored by: Auxito
1997 F250 problems
Old Oct 31, 2012 | 07:52 AM
JWGJR_H's Avatar
JWGJR_H
1997 F250 problems
I have an F250 titled 1997, suspect was built in 1996. It has the 5.8l EFI engine.
Recently rats chewed up injector connector wiring of #3 & 4 injectors. The wiring was shorted out on these two injectors. The engine would run, but only on 4 cylinders.
I have since replaced the connector wiring. The engine still runs the same as it did, (4 cylinders only), before replacing the wiring. No improvement at all.
I have re laced the plugs, plug wiring, distributor cap and rotor and the ignition control module without success.
Help would be greatly appreciate.
Thank you, Jerry
Old Oct 31, 2012 | 11:37 AM
Torky2's Avatar
Torky2
Hi Jerry,
Your 1997 F-250 is a HD (heavy duty), which uses the old body style. The Forum you are in here includes the 1997 F-250 LD (light Duty), which uses the body style of the new-for-1997 F-150.
If you can, please edit your post to delete it, and repost in the proper forum for your particular truck, which is:
1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucks
Which can be found here:
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
I know it's a bit tricky, the 1997 F-250 HD and 1997 F-350 are tucked away in a 1987 - 1996 Forum that use the same chassis. You're not the first to do this...
Old Oct 31, 2012 | 05:26 PM
JWGJR_H's Avatar
JWGJR_H
changed to the proper forum, thanks, Jerry
Jerrywgroah
Mar 19, 2013 07:58 AM
JWGJR_H
Nov 1, 2012 07:07 AM
ladystroker
1997 - 2003 F150
Oct 27, 2012 11:26 PM
lisagoud
Aug 15, 2005 05:39 PM
