Sponsored by: Auxito
Does this make sense?
Old Mar 18, 2013 | 06:45 AM
samfissure's Avatar
samfissure
My 2001 F-150 4.6L was hestitating around 1500 RPM and the check engine light was on, dealer said the oxygen sensors needed to be cleaned. Had the work done and the problem still exisits, the check engine light intermittently came on. I tried 89 octane fuel and the check engine light is off and the engine runs smoothly. I'm just a weekend mechanic and can do mostly basic stuff but the only time I've come across something like this is when I accidentally put 87 octane in my bike. Does this make sense?
Old Mar 18, 2013 | 08:52 AM
usgolf2012's Avatar
usgolf2012
Does it clear up beyond 1500 rpm?
Old Mar 18, 2013 | 09:15 AM
samfissure's Avatar
samfissure
Since putting in the higher octane, it's cleared up entirely. I'm trying to understand why.
Old Mar 18, 2013 | 12:49 PM
Bluegrass 7's Avatar
Bluegrass 7
You can't make sense of it because the CEL and code/s should have been known first, as a reference.
Ox sensors are never 'cleaned' by a dealer. They won't normally fool around with such actions, for the 'unrelability' of it.
They replace them. You really don't know what they did.
Fuel octane:
Besides what's in the formulation, higher Octane slows the rate of combustion in the cylinder.
How this all ties togather in your situation is anybodies guess.
I would even say that if your lucky the CEL and code will come back so you/we can get a basis of what the computer sees as the problem.
Then address the problem.
Until then it's only guessing.
I hope you can see the common sense put forth.
Good luck.
Old Mar 18, 2013 | 02:24 PM
samfissure's Avatar
samfissure
Got it - stupid question thanks for clarifying.
cecilt
Oct 11, 2015 08:04 PM
Jeff Dodson
29
Dec 16, 2008 09:29 AM
FYRETEK
Modular V10 (6.8l)
May 16, 2005 10:09 PM
Three_in_One
Modular V10 (6.8l)
Jul 15, 2003 04:17 PM
marmot
1983 - 2012 Ranger & B-Series
17
Feb 23, 2003 06:32 PM
