400 motor problems
Old Mar 17, 2013 | 04:11 PM
400inatruck's Avatar
400inatruck
400 motor problems
On my 400, I have the EGR blocked off. I have the dizzy hooked up to a vacuum port on the intake. I have a Holley 2 barrel 2300 500 cfm carb. There is a miss and exhaust backfire on the passenger side and the back 2 cylinders are getting more gas than the front 2. I have the timing set and the carb tuned to where the driver side doesn't backfire. Any help is appreciated. Thanks
Old Mar 20, 2013 | 06:44 PM
mark a.'s Avatar
mark a.
No matter what you do a Holley 500 will not work right it will always be too rich. The Holley will 350 work great though.
Old Mar 22, 2013 | 02:10 PM
beartracks's Avatar
beartracks
500cfm is about the minimum size for a 400ci. If you still have the EGR plate under it it could be burned out internally letting exhaust gases into the intake.
Old Mar 24, 2013 | 12:44 PM
400inatruck
The hot exhaust gases are a possibility. I was thinking maybe a bad valve or two. I'll check the EGR and tell any news. Thanks y'all.
endamyrope
Apr 7, 2014 05:52 PM
jasond5150
Jul 12, 2005 01:43 AM
RumpityRump
May 27, 2005 10:18 AM
crawlfish
21
Jun 7, 2003 01:12 PM
