Prevent injector cup failures?
Old Mar 18, 2013 | 10:20 AM
Tugly's Avatar
Tugly
Originally Posted by Snowseeker
A threaded steel cup on the other hand would have been nice. Because of the different expansion rates of the brass vs the cast heads I would go with simple years of heat cycles causing the cracks over anything else.
Both of those thoughts crossed my mind as well.
Old Mar 18, 2013 | 10:21 AM
allhuntalltime's Avatar
allhuntalltime
I hade 375k on my e99 350 had replaced two injecters over that time and no glow plugs(but should have replace GP's as maintance)
A couple weeks ago had to have the heads pulled to replace bellowed GP's so replaced the cups as a preventative messure had soot and diesel smell in degas bottle after the work. I flushed system with cascade and am waiting to see if there is any other problem. Theres the catch 22 do you do the maintanace and hope its ok or do you leave it alone until there is a problem? Still stock inj and a super chip since 1999.
Old Mar 18, 2013 | 10:26 AM
timmyboy76's Avatar
timmyboy76
Brass cracks quite easily.
Could this be done?
Old Mar 18, 2013 | 11:58 AM
Tugly's Avatar
Tugly
Originally Posted by timmyboy76
Could this be done?
Disasterous mod without a full machine shop and the heads off. Sooo not worth the effort.
Old Mar 18, 2013 | 01:30 PM
Pitcrw6's Avatar
Pitcrw6
Interesting thread Rich, glad you started it.
Old Mar 18, 2013 | 01:47 PM
Skip1970's Avatar
Skip1970
I might replace my gps this year
Old Mar 18, 2013 | 07:53 PM
F350-6's Avatar
F350-6
Originally Posted by akaFrankCastle
Had you ever had the injectors out for any reason during that 350k run?
No, just torqued them down after listening to Dan preach about it for so long. The only reason I pulled them when I did is because the weather was nice and I had the time. I didn't want one to act up at an inopportune time.
Originally Posted by BadDogKuzz
We also have Chris who has 435k on stock injector cups. I think there could be a few reasons for that. First of all I am pretty sure Chris does NOT let his EGT's get out of control. I am also pretty sure he does NOT drive his truck like a punk kid !! I have seen how young guys just beat the living crap out of their trucks.
But maybe I am just a punk kid. As for beating the crap out of it, I have had to pull the bed and weld it back together when the sheet metal started to tear and some pinch welds had broken loose.
Let me ask a question here, why do they use brass any ways for the injector cup? Other than the fact that brass is easy to work with in manufacturing process. Why not make injector cups out of boron steel.
Brass is also less corrosive and won't have a reaction due to dissimilar metals or get holes in it due to lack of coolant maintenance.
Old Mar 18, 2013 | 09:31 PM
KelVarnson's Avatar
KelVarnson
To me the most obvious candidate is thermal cycling. Brass has a temperature coefficient of expansion that is almost twice that of iron. I think the engineers used that to their advantage, causing the seal to get tighter with heat. This could explain why cups showing little sealant still did not leak; the sealant might really be more about filling voids and other small irregularities.
Picture how the cup goes in, constrained at the top and bottom by the iron head, but physically unsupported in the middle, where it is exposed to the hot coolant. I think that with every temperature cycle, that cup is "ballooning" out, which would account for the commonly-seen longitudinal cracks.
My theory is that the guys who start their trucks and drive them 100+ miles are the ones who get the high mileage out of their injector cups. The guys that drive 10 miles to work and back will have the premature failures, I think. More temperature cycles for a given amount of miles on the engine.
As far as EGTs, it doesn't seem to me that they would have much influence. The dominant thermal force on the cup is coming from the circulating coolant, and it is moving by pretty quickly. It would take a LOT of energy to get the temperature in that zone to rise much at all. EGTs down near the tip could certainly heat up that end of the cup a little more, but that is where the cup is constrained by the head, so I don't think it would result in stress cracking down there.
These are just my theories.
Old Mar 18, 2013 | 09:55 PM
Snowseeker's Avatar
Snowseeker
Thats good theory!
Old Mar 18, 2013 | 10:07 PM
akaFrankCastle's Avatar
akaFrankCastle
Mongo say science hurt brain. Mongo just want drive truck and no break cup.
Kel, you sure know how to sell a theory.
Old Mar 19, 2013 | 04:54 AM
Tugly's Avatar
Tugly
KelVarnson and I are whistling the same tune here.
Breaking it down, the initial question was: Is there something we can/should do (maintenance-wise) to extend the life of the cup?
akaFrankCastle poetically summarized the general concensus: "just want drive truck and no break cup."
Old Mar 19, 2013 | 07:08 AM
jeffreyt's Avatar
jeffreyt
I'm late to the party...
I'll add a little input though to support Kel's theory. My cup was cracked near the bottom. Also, the crack didn't extend into the area that was constrained by the head, it was in the middle that is open to coolant.
I also have a theory to bounce about why they used brass. It is a better thermal conductor than cast iron and steel. Injectors work really hard, and I'm sure they produce heat that needs to be transferred out. Brass was the ideal choice because it has adequate thermal conductivity while having ideal strength and expansion/contraction properties.
Old Mar 19, 2013 | 07:33 AM
  #28
koski19's Avatar
koski19
I am curious of the retorquing the stock sticks on trucks, did you get any amount of turn out of any of the bolts? Were some at spec and some turned a bit?
I am rebuilding an old stove right now and an interesting tid bit. The wire terminals used in ovens/stoves are nickel because any other material expands and contracts to much which eventually loosens up the connection causing a burn out.
There was no turn when I torqued. Set the torque wrench to spec and turned..There was just the click letting me know the bolts were tight. All bolts were tight at the time. I have an aircraft maintenance back ground. Preventative maintenance was pounded into my head. At 20,000 feet there's no place to pull over when a problem arises. I adopted the same practices in my own vehicles. Maintenance, Maintenance, Maintenance is the key to longevity in engines and transmissions. Fluids and filter are cheap compared to repairs.
Jeff
Old Mar 19, 2013 | 07:39 AM
  #29
Snowseeker's Avatar
Snowseeker
They used brass because much like the copper washer on the end of the injector it easily conforms to the surrounding area it is being pressed into and is supposed to seal up without much aid like a copper washer.
One other thing I wonder is how thin some parts of the cups get when being formed. Like when you try to expand any metal it gets thinner and thinner till it cracks and like I mentioned brass is very prone to cracking. The heat cycles don't help. I would imagine if simply a thicker cup was used the cracking problem would be greatly reduced. That is if there is enough room to go thicker. I am curious as well if the replacement cups are thicker than say the E99's? Possibly the E99's were thinner than the rest and no one mentioned anything about it?
Old Mar 19, 2013 | 08:21 AM
  #30
jeffreyt's Avatar
jeffreyt
It's possible I guess, but from my understanding the only change was the compound. The E99 compound was more of a watery liquid, the junk on the rest is more like a paste.
