Z Arm Assembly
Old Mar 16, 2013 | 05:02 PM
68cabby's Avatar
68cabby
Z Arm Assembly
Did 360s use different z arms than 300-6? Cuz my old z arm won't fit right. Even with my pivot ball and such. Do I need a new one for the 300?
Old Mar 16, 2013 | 06:45 PM
HIO Silver's Avatar
HIO Silver
There are specific parts for the six banger vs the V8 according to the image below. The Z-bar appears to be the same.. but the engine-side pivot screws into a boss on the engine.
Old Mar 16, 2013 | 08:25 PM
68cabby's Avatar
68cabby
I don't know how though?! I looked on bronco graveyard and they have a separate assembly. My current in is too short. I have the pivot ball already but somethin ain't right
Old Mar 16, 2013 | 09:03 PM
HIO Silver's Avatar
HIO Silver
Hmmm.. the frame-side bracket has some inboard/outboard adjustability. How far are you off????
Are you referring to JBG's clutch linkage diagram? It looks like they took the factory diagram and erased all the PNs. There are three different pivots shown - the lone pivot (which I assume to be for the I-6, and the latter appear to be for an FE bracket (mounts on the front face of the engine/trans flange), and the 351M400 which mounts on the backside of the bellhousing.
Old Mar 16, 2013 | 09:08 PM
68cabby's Avatar
68cabby
It's just odd. It seems like it needs to adjust inwards cuz I can easily slip the assembly off. Yes its just the pivot ball mounted to the side of the engine block and the bracket on the frame rail..just wonder if the 6 takes a longer arm?
Old Mar 16, 2013 | 10:06 PM
Gembone's Avatar
Gembone
are you using the proper pivot? Drawing shows one specific to the 6 cyl, 7A535
Old Mar 16, 2013 | 10:14 PM
68cabby's Avatar
68cabby
I searched the number. The one I have has the little ball end on it. It poolslike the 7a535 is just a shaft. Does it have a bushing? Cuz if its longer that could solve my problem
Old Mar 16, 2013 | 10:29 PM
Gembone's Avatar
Gembone
looks like there are bushings/spacers between the z-arm and where the pivot piece attach.
Do you have those? I can't tell from the pic if there is a bushing the actual pivot rids in though. I can't see one on my truck from topside and can't get under it currently.
Maybe someone with a bit more knowledge will speak up.
The only difference I see in the diagram is the i6 uses a pivot stud that mounts into the motor that it pivots on, and the v8 has a bracket with a pin that it pivots on.
Give me a few minutes and I can double check the MPC
Old Mar 16, 2013 | 11:04 PM
Gembone's Avatar
Gembone
That is the proper part pic from the MPC to match what you need.
Are you missing the 2 pieces between the pivot stud and the z-arm?
Old Mar 16, 2013 | 11:23 PM
68cabby's Avatar
68cabby
I think I have the wrong stud..and have no idea what pieces to get!
Old Mar 16, 2013 | 11:38 PM
68cabby's Avatar
68cabby
I'm not sure which type of stud I got. It's ALL metal..not bushing. With a half round ball at the end. Could be the 302 one? I believe I gotta get another one oy. My bad. And sorry for posing on two threads..just wanting to get all views! :
Old Mar 16, 2013 | 11:52 PM
Gembone's Avatar
Gembone
I understand, and waiting for help can seem to take an eternity.
Old Mar 17, 2013 | 09:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You cannot go by parts catalog illustrations to verify if parts are correct, as these are general illustrations only. The text section is required to get specific part numbers/applications.
C6TZ-7507-C .. Clutch Equalizer (Z) Bar Pivot-Frame Side / Obsolete
1967/72 F100/350 I-6 & V8 // 1966 F100/250 240/300/352 2WD & F100 4WD from serial number 830,001.
C8TZ-7528-B .. Clutch Equalizer (Z) Bar-5 1/2" long / Obsolete
1968/74 F100/350 240/300/360/390 / 1975/76 F100/350 300/360/390 // 1972 F100 302 from serial number N00,001 / 1973/76 F100 302 / 1975/76 F150 302.
C5TZ-7A535-A .. I-6 Clutch Equalizer (Z) Bar Pivot-Engine Side / 2 9/16" long / Obsolete/Reproduced by Carpenter: $20.00 (800-476-9653).
1965/74 F100/350 240/300 / 1975/76 F100/350 300 // 1969/74 Econoline 240/300.
C1AA-7543-A .. Clutch Equalizer (Z) Bar Nylon Bushings / Available from Ford.
1965/79 F100/350 all I-6 & V8 / 1969/79 Econoline all I-6 & V8 / 1978/79 Bronco / Misc 1961/80 Passenger Cars.
97474-S .. Snap Ring-Retains bushings and felt washers to pivots / Obsolete
Myriad 1953/79 FoMoCo vehicles.
358979-S .. Felt Washer (Grease Retainer) / Obsolete
Old Mar 17, 2013 | 10:11 AM
Gembone's Avatar
Gembone
Thanks again for the clarification ND.
I have been trying to use the illustrations as reference to get the PNs from the text section.
This can be made even more difficult when you don't know the proper names for items being looked up.
I wish the DVD version of the MPC was a searchable PDF.
I am not trying to steer anyone wrong, just trying to help.
Old Mar 17, 2013 | 10:18 AM
orich's Avatar
orich
Also The throttle linkage will need to be heated and bend too line up with carb. Or change it out with a v8 one...orich
