I searched but did not find the answer. Could I use a skyjacker steering arm CA100 on my dana 44. It is listed for chevys. I measured my suburban arm and the studs are both 9/16. and the spacing is the same.
The current arm is tapered from the bottom and i would like it to be from the top. It would correct my last 2 inches plus i could eliminate the block at the same time.
I can't tell you if the Skyjacker arm will work or not, but i can tell you what arm will work...
An arm from a 76-77.5 F250, it's 2" taller than your 77.5-79 F250 arm (pic below) so you can eliminate your block.
All the 4x4 sites list that Skyjacker arm for Chevy, not Ford, what the difference with the arm is (they look the same to me) i couldn't tell you, but there must be one.
If you are just trying to be higher by being on top of your current set up you can see in the picture Montana provided the Highboy steering arm will get you a couple of inches higher.. 1976 79 Ford F 250 Front Dana 44 Factory Steering Arm | eBay
