Holley teacher needed
Old Mar 15, 2013 | 11:56 AM
F-250 restorer's Avatar
F-250 restorer
I'm new to Holley carbs. I'm looking at the 1860, the 465 cfm model, and wondered if there was any known reason to avoid it.
Use: 250 hp 300 inline 6.
I really like the new Summit Carb, but 600 cfm is a bit large for this engine.
Thank you for any input. k
Old Mar 15, 2013 | 12:59 PM
redroad's Avatar
redroad
This is what Jeg's sells with their kit 6019-DP
Offenhauser 6019-DPK Offenhauser Dual Port 6-Cylinder Manifold
Old Mar 15, 2013 | 01:58 PM
F-250 restorer
Originally Posted by redroad
Thanks. I've had the DP for years. That kit is nice, but w/o porting the head and getting a nice cam, those mods produce a fraction of what they are capable of. After porting, the next step up with performance, is to get over-size valves installed, like I have.
Old Mar 15, 2013 | 02:30 PM
redroad's Avatar
redroad
So you have a 4 barrel intake ?
and this is the carb ?
I posted the link above to show what Jeg's was recommending with their kit with a 4 barrel intake
So 390 cfm .. seems like overkill with the 465 cfm you have
Old Mar 15, 2013 | 03:33 PM
hotstuff's Avatar
hotstuff
I agree , Holley recommends there 450 CFM for small cu.in. V8s ,The 390 CFM would be a much better choice .
Old Mar 15, 2013 | 11:13 PM
F-250 restorer
With a near stock 300 the 390 would be great. I know many 300 guys who run them. However, my engine has the equivalent HP of a 390 v8 with a 2v carb. It likes more cfm than most 300's.
Thanks for posting the Jegs link. I've seen that kit before, but always enjoy seeing it again.
Rule of thumb is 1.5 X c.i. displacement, so a 450 cfm should be right.
Since I've had this engine I've run two autolite 4100 480 cfm carbs designed for 289's. I also ran a 600 cfm 4100, an Edelbrock 500, an 800 cfm Quadrajet, and am currently running a 750 cfm QJ. (The QJ is a variable cfm carb, and the tiny primaries work well on any engine, from small v6's to 500 c.i. caddy v8's.)
I don't have much experience with Holleys though, and was hoping for some general information about 4160, 465 cfm Holley.
Thanks, guys.
Brody Olson
22
Jan 8, 2014 10:46 PM
nolan62
Apr 29, 2010 12:33 PM
true blue
Jan 6, 2006 03:46 PM
stormy750
May 27, 2004 01:44 PM
