Cab swap
Old Mar 15, 2013 | 08:25 AM
aem485's Avatar
aem485
Cab swap
I'm thinking about getting a different cab for my 88 f250 and I found a cab off of a 94. I want to keep my original interior so I want to know if the dash and everything will fit without customizing anything? Also will everything on the fire wall line up on the newer cab?
Old Mar 15, 2013 | 01:23 PM
rangergirl94's Avatar
rangergirl94
Everything should fit but im not positive I used a 96 cab on my 93
Old Mar 15, 2013 | 03:01 PM
aem485's Avatar
aem485
Yeah but the 87 to 91 had a different interior than 92 to 97
Old Mar 15, 2013 | 05:41 PM
Diesel_Brad's Avatar
Diesel_Brad
You are SOL. the dash mounting points are different, the holes for the wiring harness is different, the steering column mount is different, the holes for the ECM are different. along with a bunch of other differences
So NO, they are NOT the same
Old Mar 15, 2013 | 06:22 PM
aem485's Avatar
aem485
Ok thanks but that sucks I don't get why they would make the outside the same and the inside different
Old Mar 15, 2013 | 06:47 PM
Diesel_Brad
Outside stayed the same from 80-97. Kept production costs down.
Interior changed to give updated look and harnesses are different for OBD1 and OBD2, steering column mount is a better improved design , along with all the other differences
stubbfarmer
Mar 5, 2018 11:10 AM
needs more mudd
Sep 13, 2014 07:55 PM
Pitcher
Sep 27, 2012 02:08 PM
leegbee
Jan 28, 2008 07:47 PM
90F250351
Paint & Bodywork
Jan 31, 2007 01:59 PM
