Low voltage issue?
Old Mar 14, 2013 | 09:42 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by Kayteg1
Now explain it to me, how alternator can be damaged by lower battery voltage?
I am still learning about FICM, but lot of owners use those truck in sub-freezing temperatures, so after long prewarming and long cranking the batteries are likely well below 11v for few minutes till the alternator do its thing.
If 11v is so danger for FICM the cold weather users would have it gone 10 times a season?
I've started my truck unplugged well below -15 and I do not experience long crank times nor low voltage. I have healthy batteries and a decent alternator ( I am not running a POS stock 6G, but adapted a 130 amp 3G)
I also have the b@stard post-cycle "Buzz" flash which is known for it's cold blooded characteristics.
You need to eliminate the short trips and use a battery tender if you plan to have the truck sit for extended periods of time.
You've already proven your batteries are toast. Next in line are the FICM and alternator.
Josh
Old Mar 14, 2013 | 10:13 PM
Kayteg1's Avatar
Kayteg1
Originally Posted by BLADE35
Because the ALTERNATOR will continualy run at MAX Output trying to charge Dead Battery Cells
It will burn itself up in time
You've got it right that Ford alternators don't like to work and I replaced 2 on older Ford. But even if they run at max output, what I doubt failure ever happens just for batteries charging, Ford alternators mostly fail due the electronic problems. Haven't heard about one crapping just because the load was big, although I guess that might happen.
I do own 40 years old alternator in my motorhome, that I am using for powering roof AC at 1500W AND recharging 400 lb of batteries in 3 banks and it have not failed yet.
After boiling coffee and roasting chicken wings for 3 days of camping the batteries take quite a bit to recharge.
Old Mar 14, 2013 | 10:15 PM
MisterCMK's Avatar
MisterCMK
Call me tomorrow lee.
Old Mar 15, 2013 | 08:33 AM
Misky6.0's Avatar
Misky6.0
Originally Posted by Skattracker3
I have been seeing low voltage on my Scan Gauge after start up. It has been in the 20 deg F lately and I have been driving my truck to work. I have not been plugging it in at that temp as it starts pretty good.
I noticed on Monday that when I started the truck it turned over slowly but thought it was because it had sat for 8 days. Next morning started it and it started good but the voltage on scan gauge was 10.9 volts. It sat at that voltage and then crept up a little until the high idle kicked in and then it went to 13.6 volts.
I have been watching it and pretty much same every morning. Was at work 12 hours yesterday and started it and drove it to put in fuel, (10 min run time) filled up tank and it turned over very slow but started. Voltage read 9.8 volts but went up quickly. Drove home (15 min) and shut off, checked volts with koeo and it was 12.4 volts. Load tested both batteries (two yrs old) and load tested good.
Sorry for the novel but is my alternator going or somthing else or normal?
How old are your batteries?
It sounds like they need to be replaced.
2 new batteries produced a HUGE difference for me.
You risk damaging your FICM if you don't fix it !
My voltages now (it was 46* this AM) immediately after a cold start
WITH GP on - is now 11.7..
However (although unlikely) it could also be a poor connection
which reduces the alternators ability to adequately charge the batteries...
I'm in FL, and we rarely get below 50 in the "winter".
Still, my prior batteries would give slow crank after sitting for
the weekend, I noticed my voltage (analog voltage gauge wired to
under-dash fuse panel) would drop to 10.4-10.7 "sometimes".
Whisker
Nov 14, 2014 05:21 PM
bigred66
Jan 21, 2013 09:51 PM
TJK1
Dec 1, 2011 10:58 AM
MarkMoore
Nov 25, 2010 11:34 PM
Polkster
18
Oct 14, 2009 03:43 AM
