pulling cab this weekend
Old Mar 14, 2013 | 02:07 PM
BRay09's Avatar
BRay09
I'm pulling off my cab of my 06 f250. Is there any short cuts that I should know about before I jump into this? I'm doing head studs, egr delete, coolant filter, stand pipes and dummy plugs, head gaskets and glow plugs. Anything else I should do while I have it off?
Old Mar 14, 2013 | 09:36 PM
BLADE35's Avatar
BLADE35
As you may know you do not need to pull cab for That stuff Just throwing it out there
If you still decide to pull the cab PM Vince Vloney a FORD Tech on here and he has a Link to info on pullen CAB
Ford Truck Enthusiasts Forums - View Profile: vloney
Old Mar 14, 2013 | 09:40 PM
BRay09's Avatar
BRay09
I'm not fighting with it hanging over the engine bay, dropping parts or tools and only having so much space to do this or that. I'll feel better knowing I got the heads torqued right with it off. Thanks for the heads up though, I appreciate it
Old Mar 14, 2013 | 09:53 PM
m-chan68's Avatar
m-chan68
What type of body configuration (ie crew cab, super cab or regular cab)? Manual or automatic? ESOF 4x4 or manual 4x4 or 4x2? Fog lights or no fog lights? The answer to those questions will determine the exact steps necessary for pulling the cab on your truck.
Old Mar 14, 2013 | 10:00 PM
BRay09's Avatar
BRay09
4 full door with auto trans, ESOF and fog lights
Old Mar 14, 2013 | 10:12 PM
m-chan68's Avatar
m-chan68
Okay, you'll have eight cab to frame fasteners in total. Three 24mm bolts, three 21mm bolts and two 18mm nuts (both very front beside the charge air cooler).
Other than your ususal ground straps, parking brake cable, shifter cable, three HCU brake lines, steering shaft and main battery positive cables, it's pretty straightforward.
Kuboita
Nov 24, 2018 09:12 PM
JnastyG
Sep 3, 2010 01:55 AM
zhigaag
Mar 6, 2006 04:26 PM
