Raddling when starting
Old Mar 14, 2013 | 12:28 AM
Cowboy-rig's Avatar
Cowboy-rig
Exclamation Raddling when starting
Sometimes when I start my 89 f250 7.3 it raddled really bad like something's really lose. But as soon as I give it a little gas it goes away... Can't find anything lose. What mite this be???
Old Mar 14, 2013 | 04:35 AM
GNR22's Avatar
GNR22
Where does it sound like it's coming from? I've seen several trucks with 7.3 IDIs that have flywheels that chatter and need to be replaced. But those usually only chattered when you shut them off.
Old Mar 14, 2013 | 10:58 AM
92 Black Nite's Avatar
92 Black Nite
It may just be a part of your Exhaust that is loose. Check brackets and catalytic converter shields. Hope this helps
Old Mar 14, 2013 | 10:32 PM
Cowboy-rig's Avatar
Cowboy-rig
Can't find exactly where. Just the whole motor. Stops wen I give it gas. My buddy said it could be sucking in air do to a leaky injector cap... Thanks for replying to help. Nice to get other opinions
Old Mar 15, 2013 | 12:13 AM
GNR22's Avatar
GNR22
Have a couple people get by the truck and start it and narrow down where it's coming from. Just a thought.
Old Mar 15, 2013 | 10:44 PM
Cowboy-rig's Avatar
Cowboy-rig
Ima do that first thing in the morning.. Good idea. Thank you
Old Mar 16, 2013 | 06:41 AM
bashby's Avatar
bashby
Are you setting the fast idle before you start it? You should press the accelerator down before you start it. I think the starting procedure is on the visor. IIRC, below 30 deg hold it at 1/2 throttle, when its really cold, full throttle.
tormentedfaith
Mar 29, 2017 06:39 AM
hoss95
Feb 12, 2010 02:35 PM
chrisjrosenbohm
19
Jan 9, 2005 07:00 PM
tediesel
Exhaust Systems
Mar 5, 2002 05:04 PM
