fuel problem need help...fast
Old Mar 12, 2013 | 05:58 PM
captain2207's Avatar
captain2207
I don't use my front tank often but I get home today,smell raw gas look at gas coming out of filler door.tank is about 1/2,and rear is just below 1/2.I just looked again and its starting to seep out of front filler door again.how do I fix this issue.thanks all
Old Mar 12, 2013 | 06:01 PM
rla2005's Avatar
rla2005
The front fuel tank Fuel Delivery Module (FDM) has a bad shuttle valve which is allowing the return fuel from the rear tank to fill the front tank. A VERY common problem on this vintage truck. Search on crossflow in this forum.....
If the fuel gauge is reading half full then you also have a bad fuel sending unit and/or float. Another very common problem.
Best bet, replace the entire front Fuel Delivery Module (FDM). Then wait for the rear one to do the same thing.
Old Mar 12, 2013 | 06:05 PM
captain2207
Ok but how do I stop it now so I don't lose all my $4 gallon of gas
Old Mar 12, 2013 | 06:10 PM
DBGrif91's Avatar
DBGrif91
The only thing to do is pull the fuel pump relay or unhook the battery to get it to stop.
Old Mar 12, 2013 | 06:31 PM
captain2207
Can I drive it?or will it make it worse?it stoped on its own.I need to re-read the post about this,but I'm assuming the fdm is in tank?
Old Mar 12, 2013 | 06:41 PM
captain2207
Ok I think I got this.thanks again
Old Mar 12, 2013 | 06:42 PM
rla2005's Avatar
rla2005
Correct, inside the tank. I assume there must be a problem with the existing front FDM? Otherwise run off the front tank.
Old Mar 12, 2013 | 06:47 PM
captain2207
I use rear tank mostly due to what I belive is bad front pump.it'll go great down road...take off/acceleration is different story.so I'm going to call parts house it'll be front tank fdm?that's the one filling up.and is it ok to drive it?
Old Mar 12, 2013 | 07:11 PM
rla2005's Avatar
rla2005
If you keep driving the truck it will continue to fill the front tank @$4/gal.
Old Mar 12, 2013 | 07:23 PM
captain2207
I called parts house.motorcraft $400.I almosted peed on myself.they have a carter at $159.they aren't sure if it comes with fdm.but it says motorcraft has,pump strainer fdm gasket sending unit etc.does anyone happen to have a pic of complete unit so I know what I'm looking at at parts house?thanks all for your help
Old Mar 12, 2013 | 07:42 PM
rla2005's Avatar
rla2005
Here is a line drawing:
Here is a pic of the entire assembly:
courtesy of subford
Old Mar 12, 2013 | 08:06 PM
Rico47635's Avatar
Rico47635
Whoever designed that dual tank system for Ford needs to be taken out to the nearest tree and hung.
Old Mar 12, 2013 | 09:35 PM
ptarno's Avatar
ptarno
Check the relay Mabey it's getting hot and sticking. What I don't understand if both tanks are half full why would it spit fuel from front unless gauge is bad and tank is really full. I would stick both tanks just to confirm the level of fuel you got in them. then swap relay just to eliminate it. Its alot cheaper than the FDM. would also check venting might be building pressure in the tank. Sometimes when I shut down my 460 and walk by the back of the truck (dual tanks also) I get a strong smell of gas.
Old Mar 13, 2013 | 04:10 AM
rla2005's Avatar
rla2005
I did make one assumption here....the OP's truck is 1990 or newer. 1984 -1989 model dual tank trucks used a three pump system with a dual function reservoir to switch between tanks. If this is the case the reservoir is most likely bad. They can be disassembled and potentially repaired.
Regardless the previous post with the theory of a bad relay is not plausible IMHO.
Old Mar 14, 2013 | 09:31 AM
captain2207
Update...I have called big parts houses,the pump is $500.oreillys has got a new plastic tank,pump,New strapes,and 3year warrenty for $349.ill keep tall posted.
