Glow Plug Module
Old Mar 12, 2013 | 05:40 PM
fd1109's Avatar
fd1109
Glow Plug Module
How can I tell if this isworking ok . Thanks
Old Mar 12, 2013 | 05:59 PM
howellt39's Avatar
howellt39
Do you have the relay or the module? Relay is a 4 pole unit, module is the silver box with two large plugs located on the top of the passenger head. Modules were normally on CA trucks.
If it's a relay, check that you have 12V present at both large poles with the key on engine off. 12V present at only one pole with the key off. Quick check.
Old Mar 12, 2013 | 06:01 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
As stated above, unless your truck is a Cali model, it has a relay. If you do have a Cali truck/GPCM then you should be getting a code if it is bad.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Mar 12, 2013 | 07:04 PM
Km1210's Avatar
Km1210
Like others have said, do you have a Glow Plug Relay (non-California trucks or Excursions) or Glow Plug Control Module (California and Excursion models)?
If it's the GPR, take a voltmeter and test the 2 posts. Battery side should be constant 12 volts. Glow plug post should be around 12 volts with key on engine off. If glow plug side shows nothing, time for a new relay.
I'm better at helping people out with pictures.
Glow Plug Relay:
Glow Plug Control Module:
jtorrez22
13
Jul 10, 2015 05:14 AM
Larry Wall
18
Dec 16, 2014 02:30 PM
pbgsho2
May 15, 2012 04:40 AM
safetyguy2001
Aug 18, 2004 05:31 PM
