6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Engine Stall
Old Mar 12, 2013 | 02:00 PM
billyopen541's Avatar
billyopen541
Engine Stall
I've been on the sidelines for awhile in the Excursion Forum but recently purchased a 2008 F-350 Crew SRW w/ 6.4 with 57k. The truck runs great just made a 1000 mile weekend trip but it has started to just shut off when you are stopped with your foot on the brake. Wrench sign shows in odometer.......engine starts on 3rd try and then may not occur for awhile.
Any ideas? I have warrenty left and also purchased a Ford Extended warrenty had a 2005 6.0 with issues prior to the Ex.
Old Mar 12, 2013 | 03:01 PM
senix's Avatar
senix
EGR valve comes to mind...or it could be fuel rated. when was the last time filters were changed and who did them. Did they use OEM filters?
Ever drain the fuel water separator?
Wrench is for the powertrain..obvious since it died.
Old Mar 12, 2013 | 03:21 PM
billyopen541
I had the Ford Dealer send me the shop report yesterday to see if the Fuel Filters were changed. Nothing listed so that is where I was headed 1st...... truck is used and of course no info. It only has 58k so is it to early for the EGR?
Old Mar 12, 2013 | 04:25 PM
senix's Avatar
senix
EGR's are not problematic unless you do an extreme amount of idleing in which case you should then high idle it.
EGR coolers is the other concern. You don't want them to leak. They are fine as long as you do the proper coolant maintance and don't let them run dry.
You can do the filters yourself if inclinded just be sure to use only OEM fuel and Oil filters on this truck.
No jiffy lube places.
Ford's quiklane is fine.
speakerfritz
Dec 4, 2015 12:31 AM
TMartinLVNV
Jul 8, 2009 07:01 AM
wtaylor71
Jun 7, 2009 06:15 PM
fs2000
May 24, 2007 11:39 PM
lpbaca
Aug 30, 2005 10:08 PM
