Sponsored by: Real Truck
v10 fuel issue
Old Mar 11, 2013 | 06:24 PM
lil mike's Avatar
lil mike
v10 fuel issue
i have a 2001 excursion with a v10 ,it quit going down the road .
got it home shot carb cleaner in intake and it fired ,removed fuel filter and turned ignition on and fuel pump pumped! put a new filter on (old one was pluged) and still wont run! any ideas??
Old Mar 11, 2013 | 07:24 PM
mikeismadness's Avatar
mikeismadness
Are you getting spark? What's your fuel pressure? These things you need to find out.
Also need to know if any codes are set
Old Mar 12, 2013 | 05:45 AM
lil mike's Avatar
lil mike
No codes and yes it fires on carb cleaner! There is no ports on the fuel rail I can see, so where do I get fuel Psi from?
Old Mar 12, 2013 | 07:42 AM
mikeismadness
With the 2v I'm not entirely sure. Someone will chime in I'm sure. Or google search checking fuel pressure on a v10, something will pop up
Old Mar 12, 2013 | 08:23 AM
lil mike's Avatar
lil mike
It says there is a port on the fuel rail, I can't find one!
Old Mar 12, 2013 | 09:48 AM
kameronth's Avatar
kameronth
There is a schrader valve on the passenger side fuel rail.
Old Mar 12, 2013 | 10:44 AM
northwindone's Avatar
northwindone
Here is a picture of where it is located. This is the intake manifold from my '99 with the fuel rails still installed. the left of the picture is the front. You can see the schrader valve right under the coolant tube on the upper right of the picture.
Old Mar 12, 2013 | 12:16 PM
lil mike's Avatar
lil mike
Thanks, I will see what I can do now! Any idea what Psi should be?
Old Mar 12, 2013 | 12:34 PM
mikeismadness
Idle should be around 35-38 if I remember correctly. Turn the key on and off 3 times should get you to almost 40 psi. If that's a no go, then you probably have a weak fuel pump
Old Mar 12, 2013 | 07:22 PM
lil mike's Avatar
lil mike
Cool thanks I had 20# so I took the tank out, holly wow that thing weighs a ton with a quarter of a tank of gas!!
Old Mar 13, 2013 | 05:28 PM
lil mike's Avatar
lil mike
Ok I got a new fuel pump on and still won't run, any other ideas?? I need my truck and can't afford taking it to a dealer!! Please any help would be appreciated!
Old Mar 13, 2013 | 05:31 PM
mikeismadness
Is there any obstruction in the fuel system?
Old Mar 13, 2013 | 05:47 PM
lil mike's Avatar
lil mike
Not that I can come up with, clear to the filter and getting good flow out the test port on fuel rail!
Old Mar 13, 2013 | 06:23 PM
lil mike's Avatar
lil mike
i had a idel code pop up at first but not sure if that has anything to do with it?
Old Mar 13, 2013 | 09:00 PM
mikeismadness
If you could get the exact code that would help I'm sure
