i got this truck over 10 yrs ago and finally decided that i want to repair the a/c. the problem that i encountered is the placement of the compresor. i've been looking for a diagram of a complete engine bay so as to decide which brackets to use to mount the compressor. i have both sets of brackets one to mount the compressor side ways and the other to mount it vertical. which one is right? can anyone help me out?
1981: Two different types of A/C, the parts do not interchange!
1) Factory installed integral A/C is combined with the heater. The A/C controls are located in the same panel as the heater controls.
2) Dealer installed Economy A/C is not combined with the heater. The two A/C switches are located on a bezel.
Nobody is answering because you're not giving enough information.
Bill has already explained the parts are different depending on factory or dealer A/C.
You have factory, OK, that's a start.
Now, what engine? Ford had many different possible configurations.
Please provide all the basic information whenever you ask a question out here - what year, model, engine size, transmission, 2WD or 4WD.
It would also be appreciated if you went HERE and finished filling out your profile; what you enter in the Location field of the 3rd pane will show up in the top-right of each of your posts, thanks.
when i buoght the truck it had a 460. i didn't like to feed the monster, so i installed a 89 302 roller with a stock mustang cam. the first time i repaired the ac(factory air)
i had to hunt for 4 months to find a bracket to mount the compressor in a vertical direction. that bracket fit but had a harmonic vibration bad enough to break the bolts holding it on. i found another bracket about a year ago that mounted the compresor in a horizontal position. before i do the work with a similair result, witch way is the most likely way the truck came from the factory?
No 1981 F100s came with 460s in them from the factory. If you post a picture of the Certification Label on the driver's side door jamb, we can tell you a lot about how it was originally built.
In 1980/81, the parts book says they used a York compressor mounted on its side, I attached a bunch of pictures that should help. (The picture of the 1988/89 configuration is just FYI.)
