Miss in Engine
Old Mar 9, 2013 | 05:44 PM
Per4mance's Avatar
Per4mance
Miss in Engine
I've been lurkin in the back ground reading all the posts here at the forum,first off you guys are the nicest bunch. It is almost like being at my Corvette forum C3 Vette Registry.Let me give you a little back ground on my truck, it was a wreck out of Pa.I bought from a wholesaler,put it all back together for my vacation out west this summer,needless to say it looks like a brand new 2006 inside and out. I still have a few little things to do to it and it will be better than new. (ie. all the bugs worked out ) It always had a miss from the time I put it on the road,I changed the oil and filter,fuel filters and coolant,all motorcraft, rotela t6 and elc coolant, 2 brand new batteries are in it and a 200 amp alt. All the specs I can check are good deltas ficm etc. I don't have the fuel pressure ck yet and I want to know how you find out the cylinder that has the miss in it (you can't feel it but you cant hear it especially if you get on it cause it has 4 " straight exhaust ) new to getting into these Ford 6.0 but not new to diesels Is there anyone that can set me straight thanks in advance ....Bill
Old Mar 9, 2013 | 05:49 PM
chetspencer's Avatar
chetspencer
I'm dealing with a miss issue also, I've been sharing this video about testing hope it helps.
I'm changing push rods at the moment.
https://www.ford-trucks.com/forums/1...l#post12905575
Old Mar 9, 2013 | 05:58 PM
Per4mance's Avatar
Per4mance
Thanks for the video Chet but I don't think it's a mechanical problem ,it runs too smooth,I think it's an injector or a ficm problem ( the batteries were stone dead when I got the truck and they were using jump boxes to start it ) I'm thinking of pulling the FICM and opening it up to see what up inside, I've ck'd the harness and moved it around but nothing has changed
Old Mar 9, 2013 | 06:02 PM
chetspencer
We my 2005 EX runs like a bat out of hell, but it miss's at idle and has a smoke problem that it never had before. I changed 4 injectors on the driver side. If I would have done the 30 second test in the first video I would have saved a lot of time knowing it was beyond injectors.
It takes no effort to do the test. Just make sure the key is in your pocket.
Old Mar 9, 2013 | 06:10 PM
Per4mance's Avatar
Per4mance
i did that test when I was putting the truck together, I think I'm going to do a compression test as soon as I can figure out how to do it on this 6.0 I have the diesel tools I just got to find out the right method
Old Mar 9, 2013 | 06:35 PM
fspadave87's Avatar
fspadave87
Ok here we go 02 7.3 330000. Miles has noise sound like ex leak,rock tap,or knock all depends on where u r in the throttle
Did compression test 400 psi across the board now here's the kicker if u mat it to the floor
The fuel pump don't keep up when it hit about 10 psi sound go away just driving has 80 psi
N u can see the fuel pressure gauge jump with the sound
Old Mar 9, 2013 | 06:39 PM
chetspencer
Was your test a pass or fail or like the first or second video?
Old Mar 9, 2013 | 06:53 PM
Per4mance's Avatar
Per4mance
Pass like the first video
Old Mar 9, 2013 | 07:23 PM
chetspencer
Glad to hear it!
Old Mar 10, 2013 | 08:02 PM
Per4mance's Avatar
Per4mance
Well I took out the EGR and it had some build up on it,vacuumed out the hole with the shop vac and cleaned it up and reinstalled it miss is more pronounced now.this is starting to **** me off No codes and no clue with the livewire. I've got to get a shop manuel
Old Mar 10, 2013 | 09:25 PM
chetspencer
But you have an even crank test right?
Old Mar 10, 2013 | 09:44 PM
Per4mance's Avatar
Per4mance
Yes I ck,d it twice. I got a scanner coming tomorrow..... I hope. I got to get a fuel pressure adapter too I want to ck it too
Old Mar 10, 2013 | 09:48 PM
BLADE35's Avatar
BLADE35
Go to Chets Thread and read about the Bubble test its easy and nothing Special required to do it
With AE thats Ford enhanced you can do a Contributation test
Old Mar 10, 2013 | 09:50 PM
chetspencer
I think as long as you have even crank your golden.
Old Mar 10, 2013 | 09:52 PM
chetspencer
And I guess you want to pray for bubbles. I know I was.
