Hot wire to trailer
Old Mar 9, 2013 | 02:46 PM
Team roper's Avatar
Team roper
Exclamation Hot wire to trailer
My 2012 f350 won't run the auxiliary lights inside my horse trailer. I've checked the fuses and run a test light on the hot wire out of the plug on the pickup and I've still got nothing. Anybody have a solution? Thanks
Old Mar 9, 2013 | 05:30 PM
labman1014's Avatar
labman1014
I remember my 06 and 08 F150 needed a fuse to be installed in the under hood fuse box to activate that. Have u checked there?
Old Mar 9, 2013 | 08:59 PM
Stebs's Avatar
Stebs
I believe that there is both a fuse or two and a relay for that particular terminal.... Look in the fuse section for anything labeled "trailer tow battery charge"
Old Mar 12, 2013 | 12:33 PM
Eric H's Avatar
Eric H
My truck has to be running for the aux lights in my cargo trailer to work
Old Mar 12, 2013 | 02:41 PM
paraskr's Avatar
paraskr
Mine will work on acc switch on ignition as well, not engine running. I also had to put a fuse into the proper location of fuse box in engine bay. It did not come with one from factory, even though it had factory tow package.
Old Mar 12, 2013 | 06:51 PM
Snowseeker's Avatar
Snowseeker
My 96 and now my 03 the ignition has to be to the run position to have power at the wire. It even says that in the owners manual. Have you read your owners manual?
Old Mar 12, 2013 | 07:21 PM
JWC 3's Avatar
JWC 3
A must read for all vehicle owners ! You can get some good info from them . Not as good as the once were . My 73 VW even had engine specs listed in the manual . Valve lash , point gap , adjustment procedures for many items . But , you can still learn a lot !
Old Mar 13, 2013 | 06:38 AM
rlt7272's Avatar
rlt7272
As long as one person with internet reads the manual the rest of us can slide. Sorry for the hijacked thread and thanks for the information you saved me some page turning too.
Old Mar 13, 2013 | 07:26 AM
Snowseeker's Avatar
Snowseeker
That is true! I sort of miss the old manuals that had torque specs, parts explosions and part numbers, and whatnot. It wasn't just a manual, it was a blueprint of the vehicle.
Old Mar 13, 2013 | 07:11 PM
JWC 3's Avatar
JWC 3
Tell me , now they explain how to use the radio , child restraint tie downs , They try to tell you how to use the complex navi systems . Oh , and if ( insert here ) light comes on , take it to the nearest dealer . The owners manual for my 53 Pontiac is much better than my Mounty . In my opinion . With my Ferguson manual I can almost rebuild it ! They ( the powers that be ) do not want everyone working on their autos . That is why it cost s a few grand each year for my shop to keep the equipment up to date !
Old Mar 13, 2013 | 07:28 PM
Snowseeker's Avatar
Snowseeker
I have a manual for an old hand crank to start wisconsin motor (water pump) that has absolutely everything in it including a phone number for ordering new parts. It has it all from torque numbers for the connecting rods to how to grind the piston rings to get the right gap.
Now they tell you how to start the car and put it in gear. Everything else "See the dealer".
Old Jul 31, 2013 | 10:07 AM
Harleyrider206's Avatar
Harleyrider206
2012 F150 Trailer running light fuse #77 on your fuse panel under the hood. It is a 1/2 square 20amp... make sure you use your owners manual to find the location. It pulls straight up to remove it...Good Luck
Old Jul 31, 2013 | 11:15 AM
cameeks's Avatar
cameeks
Does the 2012 F350 even come close to the Excursion's wiring harness?
Old Jul 31, 2013 | 01:01 PM
Jesser02EX's Avatar
Jesser02EX
I wondered why my market lights didn't work. I'll dig out my shop manuals and wire harness book to see what I can did about the fuses. Great topic
Old Jul 31, 2013 | 10:15 PM
Stebs's Avatar
Stebs
Look at the number of posts from the previous poster. Im guessin a new guy that doesn't know where hes at on the forum.
